1700 WHINE
ohiojack
1700 WHINE
Post by ohiojack »
Is a too tight belt the cause for a whine at 60 mph. If I increase the speed to 65 it goes away. Just curious. ohiojack
Champion Trike
Been liked: 4 times
Re: 1700 WHINE
Post by hank43 »
Sometimes I get that on my 1700 trike, but it usually goes away if I stop at Starbucks and buy her a coffee. :rolling: :rolling: :lol: :laughing:
But seriously, my 1700 has whined like that ever since I got it, first as a 2 wheeler, then as a trike. It starts and stops on it's own, but I have discovered that if I squirt the belt with a little soapy water, it quits, at least until it drys out. I learned that little trick from a mechanic at a Kawasaki Dealership couple of years ago.
Bronson
Current bike(s): 2009 Voyager 1700
Re: 1700 WHINE
Post by Bronson »
When I got my 2009 it also had a whine. I was informed by a tech.
where I got the bike it was likely the belt was to tight. Losened
the adjustments one turn and has been quiet ever since
Bronson
Been liked: 81 times
Re: 1700 WHINE
I agree with Bronson, because that's what I was told to do. I did and at first I had the belt a little to loose. I then readjusted it (marked the swing arm and the adjuster so that whenever I remove the rear wheel its easy to adjust the belt.
you can see the rusted groove on the swing arm (both sides are marked) but only made these marks after a lot of trial and error. Which was trying to keep the belt in the middle of the rear sprocket.
Richard Pepin
Current bike(s): 2012 Black/Gray Voyager (SOLD)
1996 Voyager XII (sold)
Re: 1700 WHINE
Post by Richard Pepin »
Hey Don, how much deflection do you have on the belt?
2012 Black/Grey Voyager
1996 XII bought new (sold)
tnwareagle89
Current bike(s): 2001 Vulcan Drifter 1500
2011 Vulcan Voyager 1700 ABS
Re: 1700 WHINE
Post by tnwareagle89 »
My 2011 Voyager - purchased it 3 months ago - had a significant whine, especially when slowing down
I took it to my dealership and they tightened the front pulley (impact wrench) - it had backed off a little and was causing the belt to be slightly out of alignment
The tech also checked tension to make sure it was within spec
Picked up the bike earlier this week, it's much quieter - the whine when slowing down is almost gone
Hope that helps
Todd
