K Act ABS problem
Wayno
6
Current bike(s): 2009 voyager
K Act ABS problem
Post by Wayno »
hi guy, g’day from Australia.
Has anyone had an issue with their K Act or ABS?
I’ve recently had an issue with my right front caliper coming on hard and my rear coming on lightly without me applying the brakes. Happens at speed. Got so hot at one point it boiled the fluid.
I’ve rebuilt the calipers, right front was a little tight probably because it got so hot. Nothing to explain the problem so a mate suggested there might be a problem with the K Act system.
Any help would be appreciated. Cheers, Wayno
Been liked: 78 times
Re: 1700 K Act ABS problem
... we have another Kaw side of the Voyager family for the Vulcans...
VROC - Vulcan Riders and Owners Club, as you ride a Vulcan and there
are some knowledgeable folks over there, I posted your problem.
BTW, you can go to VROC.org and sign up... free and easy, the forum you
want is techtalk where most of the conversations and all of the technical
issues come up.... not much technical going on over there for a while...
Go take a look, if ya are interested... FWIW If I see anything of interest,
I'll bring it back here....
Re: K Act ABS problem
... one reply from a friend..
Dirty or bad ABS sensor giving a false reading of wheel speed could be a cause. Check the gap between sensor and the slotted wheel rotor.
Wayno
6
Post by Wayno »
Cheers Cranky, I’ll check out the speed sensors and make sure they’re clean.
Wayno
6
Post by Wayno »
Pulled the fuses for the abs and KAct and it seems to be better. So definitely a problem with the abs/KAct system.
Champion Trike
Been liked: 4 times
Post by hank43 »
Do you have a shop manual? There is a somewhat lengthy section on how to read the service codes on your bike, (if any) have you done this? Also, be aware that there are certain things electrically you do not want to do on this system, so you should read the ABS-K ACT chapters in the shop manual. PM me if you need help with getting a manual...
