Water pump leak
Water pump leak
I had a large puddle of antifreeze under the voyager this morning. Had a constant drip coming out of the weep hole of the water pump. I pulled the pump and the oil/water seal has not slid out of place like it's prone to do.
My questions are: Is this pump rebuildable and is the inner seal even available?
Thanks in advance for any and all advice
HarryL
HarryL
- Current bike(s): 1995 Kawasaki Voyager
Re: Water pump leak
Do a search on this forum, I know there's somebody that sells rebuild kits but I can't remember who it is. I replaced mine last winter and I remember somebody saying that the rebuilt ones last longer than the replacements. I can't verify the longevity claim, maybe somebody else can.
-John-
95 Voyager XII
Past rides
85 Voyager 1300
08 Kawasaski 500 LTD
02 Yamaha V-Star 1100
96 Yamaha Virago 750
81 Honda CM400T
72 Honda CB175
Re: Water pump leak
Take a look at this thread....
viewtopic.php?f=3&t=8770&p=66244&hilit= ... ump#p66244" onclick="window.open(this.href);return false;
-John-
95 Voyager XII
Past rides
85 Voyager 1300
81 Honda CM400T
72 Honda CB175
- Has liked: 795 times
- Been liked: 266 times
Re: Water pump leak
I replaced my waterpump seal when I replaced my water manifold O-rings and coolant hoses during my 2014-2015 winter service.I got them from Carl Leo. You can get his contact information on this forum,but I do not have it handy.My seal had not slid out ,but coolant was leaking on the outside of the seal, between the seal and pump housing.When I installed the seal,I put a thin layer of red locktite on the outer surface of the seal to help hold it in place.I learned that about 6-7 years ago in our farm equipment repair shop to hold seals in place which are not a tight press fit.
Re: Water pump leak
I talked to Carl Leo. Because I was losing lots of coolant out of the W/P weep hole, he said that the ceramic seal had failed under the impeller which is not rebuildable.
C'est la vie
C'est la vie
Re: Water pump leak
I stand corrected, I had oil seeping out of my weephole,not coolant.cushman eagle wrote:I replaced my waterpump seal when I replaced my water manifold O-rings and coolant hoses during my 2014-2015 winter service.I got them from Carl Leo. You can get his contact information on this forum,but I do not have it handy.My seal had not slid out ,but coolant was leaking on the outside of the seal, between the seal and pump housing.When I installed the seal,I put a thin layer of red locktite on the outer surface of the seal to help hold it in place.I learned that about 6-7 years ago in our farm equipment repair shop to hold seals in place which are not a tight press fit.
- chevyman1
- Been liked: 15 times
Re: Water pump leak
I have used water pumps if you need one.
long or shout. (kew427@comcast.net)
Re: Water pump leak
I have acquired a used pump that has been sitting for about 10 years that may or may not be good. Thanks for the offer, I may make a deal with you if this one is bad.
New pumps are high dollar. The best price I found was $223!
This is a great site, thanks for all the responses, and a special thanks to Carl Leo.
HarryL
HarryL
- Current bike(s): 1987 Kaw Voyager
Re: Water pump leak
I pmed you with my number. Give me a call or text if you still have pumps. I need one.chevyman1 wrote:I have used water pumps if you need one.
Re: Water pump leak
Hello...
Recently I purchased a water pump..., but I found a leakage problem with it when I used it..., So, please suggest me something to solve my problem..????
- Highway Rider
- Webmaster
1978 KZ650 D1 SR - Has liked: 130 times
- Been liked: 32 times
Re: Water pump leak
Can you post more information on the issue that you are having
