Homemade I-Pod attachment cable
I picked up my bike a month ago and the dealer has absoultly no information on any accessories from Kaw. I have made a make shift Ipod connector to fit into the aux connection (three prong). Works but can't use the bike controls to operate the Ipod. Rode 2000 miles through West Virgina, Virgina and Tenn and was glad to have the Ipod.
- the1king
Re: I-Pod Attacment
On the Aux plug there are 3 wire colours, Blue, Green and Yellow. I assume one is a common negative, and the other 2 would be either left or right channel.jrob wrote:I picked up my bike a month ago and the dealer has absoultly no information on any accessories from Kaw. I have made a make shift Ipod connector to fit into the aux connection (three prong). Works but can't use the bike controls to operate the Ipod. Rode 2000 miles through West Virgina, Virgina and Tenn and was glad to have the Ipod.
Would you mind sharing which of the 3 Aux connection wires you hooked up to which of the 1/8" male plug (MP3 player headphone outlet plug) contacts ie when you look at the 1/8" plug there are 3 contacts. 1) tip, 2) center, 3) bottom
Re: I-Pod Attacment
I have an Ipod Shuffle and bought a jack cable at Best Buy for $10, three short pieces of 22 gauge wire and fork slotted crimp connectors (cut off one prong). Cut one end off of the Ipod jack and stripped the wires back. Twisted the sheild wire for the ground (connect to green wire on plug), the other two wires are for left and right channels and can be connected in either one. I also used a small dowle rod to keep the wire separated and wrapped electrical tape around it. Primitive but functional. Good luck.
Re: Homemade I-Pod attachment cable
I'm not home at the moment and am only going off what I remember reading on another site... but if I'm remembering correctly, the connector inside the fairing of the voyager is 4 pronged. If you look at the end of the USB connector that connects the ipod to your computer for syncing it has 4 pins. Looking at http://pinouts.ru/Slots/USB_pinout.shtml it specifies which pins correspond to what function. Pin 1 is VCC, is red and +5VDC. Pin 2 is D-, is white and Data -, Pin 3 is D+, is Green and Data+ and Pin 4 is Gnd, is black and Ground. Seems simple enough to me that four pins match up with four prongs and it's that simple.... I'll play around with it when I get home tomorrow night and see if it works. It honestly can't be "THAT" complicated....lol
Just hope I don't blowup my retirement gift from my wife...
Well, apparently it's a little more difficult that it seems....LOL. But I haven't totally given up just yet...
Okay, I give up ...... it sure seemed simple but I just can't seem to get it. Took jrob's idea and made a cable. I went to pep boys and got some male fittings. I soldered the wires to the male fittings then used shrink wrap to protect them from each other incase they touched. Works better than the FM modulator....
