rear brake pads
rear brake pads
I want to change the rear brake pads on 02 voyager Xll myself. Any pointers or pics?
- biggersm
2000 Voyager XII
1998 Suzuki Intruder 1500
1989 Honda PC 800
1982 Yamaha Maxim 750
1993 Yamaha Seca 600
1981 Yamaha XV920 (part 2)
Re: rear brake pads
RTO Welcome to the AVA. It looks like you have been with us for a while but are just now getting active on the forum.
All of the Voyager XII pads are very easy to work on. Unbolt the calipers and one of the pads will pretty much fall out in you hand. The other pad is held in place with a flat spring but once you depress it you should not have any problem.
You might as well get some DOT 4 and change the fluid too, however with the rear brakes I would recommend speed bleeders or a suction tool.
Mike and Marcia Biggerstaff
Melbourne FL
Melbourne FL
- usmalenurse
- Has liked: 7 times
- Been liked: 40 times
Re: rear brake pads
Very easy to do, I just put another set on mine 2 weeks ago. I may have to change out my rotor if these don't last any longer. This makes 2 sets I've installed in a little over 10,000 miles..
Charles Hairr
1997 Voyager XII
2016 Honda Goldwing
1997 Voyager XII
2016 Honda Goldwing
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
Re: rear brake pads
Charles,
There could be something wrong with your brakes when they only last that short of time. Check in the AVA Tech Center under brake moaning (rear or front end section), and make sure that part is greased and not sticking. This will cause your brakes to wear way prematurely. You should also only run the stock OEM brake pads, or the EBC85 pads. Although the EBC85H pads will provide exceptional stopping power, they will wear your rotors much faster and those aren't cheap. The standard EBC85 pads still provide very good stopping power without excessive rotor wear. You also want to be sure you are not riding your brakes without knowing it. My Voyager had about 13,000 miles on it when I bought it, it now has about 96,000 on it, and I still haven't changed the front brake pads yet. I just now put on the third set on the rear.
Iron Butt Member #47339
- usmalenurse
Re: rear brake pads
Thanks....will check them out. Almost ready for another oil change and some other routine maintenance anyway...
Charles Hairr
1997 Voyager XII
2016 Honda Goldwing
1997 Voyager XII
2016 Honda Goldwing
- richardb, austin
Re: rear brake pads
To help the pads slide in & out properly, don't forget to apply a thin coat of grease to the caliper holder shafts. The book specifies PBC (Poly Butyl Cuprysil) grease for hi temp & water resistance but anything's better'n nothing - don't get it on the pads!!
richardb, austin
__________________
__________________
Re: rear brake pads
You Tube has several good videos on how to change out motorcycle brake pads.
Re: rear brake pads
https://drive.google.com/open?id=1VYBjC ... jBPWD9rWQs
Hope that picture shows up. Wasn't having any success posting it as image.
I recall a thread where it was mentioned about the "tabs" being flat??
Should these two tabs be where they are? Or are these the ones that should be flat? (wondering what it's purpose is, if it is actually supposed to be flat?)
Obviously as I removed the rear brake, the pad fell out, and wasn't sure exactly how this should look, as my first attempt, with the pad behind these tabs, failed.
Bled it different ways. Light mallet taps. Moved around as I attempted to bleed, all to no avail.
Any help is most appreciated.
Danny
Danny
Re: rear brake pads
I agree on the speedbleeders. Love them.
Although right about the time they arrived, I got really good the old fashioned way :)
- Has liked: 87 times
- Been liked: 236 times
Re: rear brake pads
The 2 tangs which show as a letter "U" shape in the photo are supposed to be flat, similar to the foot of a letter "L".
Re: rear brake pads
That was it. Tabs bent flat, as Triton stated, and 5 pumps and I have rear brakes again.
THANK YOU SO MUCH.
THANK YOU SO MUCH.
- Current bike(s): 1992 Kawasaki Voyager XII
- Been liked: 6 times
Re: rear brake pads
Hi gents
I'm about to change my rear brakes. I used speed bleeders on my Harley years ago. It seems there are different sizes. Which speed bleeders do you recommend? Thank you.
- Been liked: 218 times
Re: rear brake pads
The front and rear take different sizes. The Speed Bleeders site should list them both for you, labeling which is which. I bought them, years ago, but never installed them on my Voyager. Used them on my 1979 Honda, circa 2008: worked superbly. Also used them on my 1983 Kawi 440 LTD. Loved them! Made changing the Brake Fluid incredibly simple, fast, and carefree. Need to locate the Voyager Bleeders, and finally install them... Cheers!
- Bulldogx11 (Thu Dec 30, 2021 11:25 pm)
- Rating: 12.5%
Re: rear brake pads
Hi Bruce
Thank you so much for the info. It would be great if you could share the sizes of the ones you have. I checked the speedbleeder bikechart web page and it is giving the same size for front a rear.
Front Brakes Rear Brakes Clutch
All models Prior to 01 SB7100S SB7100S SB8125L
Mine is a 1992.
Websites are not always accurate.
Thank you for your help. Really appreciate.
As I said I used them before and I love them speed bleeders.
Mine is a 1992.
Re: rear brake pads
I moved a year ago. Still sorting out the garage, as we built a second one to house our toys. Hoping to decompress the first garage in the next few months, sorting everything. At this time, I have no idea where the Speed Bleeders might be.
I suggest you contact the company and ask them to verify which ones you will need for your bike. All of the XII's should take the same SB unit, as they changed very little over the production years. Give them a phone call: Customer Support 888.879.7016. Cheers!
