Which one of these cables (of the ones seen horizontally in this pic) is the return and which on is the vroom? Note: When I click on the pic to see it enlarged the photo flips 180 degrees. So when someone tells me top or bottom, let me know if you are looking at the small pic below, of the larger, flipped version, please.
Which cable is which?
2006 Vulcan 750
- Been liked: 58 times
- Deep Thoughts
- 1
- Has liked: 7 times
- Been liked: 23 times
Re: Which cable is which?
So as to not confuse anyone who reads this thread in the future, understand that those two cables can easily be crossed over each other under that metal retaining tab. The best way to understand which cable is performing its intended function, is to simply identify its position relative to the carb linkage. The top most, or upper cable connection on the butterfly shaft actuator is in the push position, or what the parts diagram calls "close". This cable actually pushes out of its sheath downward, pushing on the cam. This is happening when the throttle is being twisted open. The lower position is pulling open the butterflies, again when twisting throttle to open or accelerating. Please bear in mind, I am speaking of a late model Voyager 12 with factory cruise. Yours may differ, but I am assuming the way the carb is set up to receive the two cables is the same regardless of the presence of a cruise system or not.
So to answer your question directly...while sitting on the motorcycle looking straight down at the carbs, the cable on the left is pushing straight down on the actuator cam. The wire rope is not wrapped around the cam. The cable on the right passes under and around the cam and pulls upward to rotate the butterfly shaft open. So even though these are called "open" and "close" cables, neither one actually forces the butterflies closed. The return spring does that. Both cables are in fact forcing themselves against carb return spring pressure. I believe Kawasaki refers to them as open or close when speaking of the action at the throttle...not at the carbs themselves. I'm still trying to wrap my head around this system. The cruise control really complicates the throttle assemblies.
- Has liked: 87 times
- Been liked: 236 times
Here is the throttle mechanism from a set of carbs I am rehabilitating.
The copper tag is attached to where the nipple of the opening cable would be inserted.
The RED arrow points to where the nipple of the close/return cable would be inserted.
- Has liked: 206 times
- Been liked: 550 times
Just twist the throttle a little and see how the cables move.
Indeed. As an aside ... the throttle rail has a CC cancel switch that I've argued is totally unnecessary because it doesn't confer any added safety at all. There are several other more effective cancel switches on brakes and the clutch. But I've changed my mind. I don't think this switch is for safety, it's to protect the CC actuator. If you're in cruise and forget it, then when you twist the throttle you're working against the actuator. This switch turns off the actuator (opens the electric clutch that locks the actuator to this whole throttle cable fiasco).Deep Thoughts wrote: ↑Wed Jul 13, 2022 6:11 amI'm still trying to wrap my head around this system. The cruise control really complicates the throttle assemblies.
2006 Vulcan 750
Thanks to the tribe-at-large for passing on the tribal knowledge on the subject. I asked because in the Tech Tip section it is written by Bruce Kauffman (in reference to removing the carbs) to remove the "closing cable" first. But Bill Overton says simply to remove them both, not stating anything about if there is one to do first.
I don't see much about what difference it makes but...... doesn't hurt to ask.
For NAILS: Both cables move when the throttle is twisted so it's a bit confusing.
I meant, see how they move when you open the throttle versus when you close it. You know what open and close are on the throttle. The carbs (even when when disconnected) rest in the closed position. Seemed pretty straight-forward the last time I was in there trying to figure it out.
