1999 Voyager XII Air Cleaner Question
Have questions about how to use these forums or the AVA Classified Ads section? Ask here, or obtain helpful hints in using the features (you must be registered to post on any of the forums, or the Classified Ads). For all other questions, please use one of the forums below.
BOBEYE22
1
Current bike(s): 99 Kawasaki VoyagerXII
Post by BOBEYE22 »
I was wondering a good place to purchase a new air cleaner element. My bike sat quite awhile and a mouse got at the air filter. Also the foam around the outside is deteriorating and sucking into the carbs.
4
Has liked: 434 times
Been liked: 393 times
Re: 1999 Voyager XII Air Cleaner Question
BOBEYE22 wrote: Mon Apr 10, 2023 10:04 pm I was wondering a good place to purchase a new air cleaner element. My bike sat quite awhile and a mouse got at the air filter. Also the foam around the outside is deteriorating and sucking into the carbs.
Look in the Tech section under "dollar for dollar".
BOBEYE22
1
Post by BOBEYE22 »
Thank you
These users liked BOBEYE22's post:
GrandpaDenny (Tue Apr 11, 2023 9:52 pm)
Rating: 12.5%
4
You'll see a post about using a Camaro filter, I think, using the frame of the stock Voyager XII filter. This is what I did, with a K&N filter. The K&N filter listed for the Voyager XII no longer exists, so I used one for whatever it was they say, I forget. Used Permatex to seal the gaps, and used a couple of layers of the rubber that came with the filter to build up the top to correct for the missing air filter hold-downs.
Has liked: 813 times
Been liked: 273 times
Hello,BOBEYE,and welcome to the AVA family :thmup:
Partzilla shows that air filter element, in stock,as part number 11013-1137,for $38.58 :clap:
sheiserman
Been liked: 14 times
Post by sheiserman »
cushman eagle wrote: Thu Apr 13, 2023 12:36 am Hello,BOBEYE,and welcome to the AVA family :thmup:
I ordered 1 through Partshark just last night. Got an email today saying it was on a national backorder and has been discontinued by Kawasaki.
That is disappointing :cry2: :thk:
I have no other suggestions. :corn:
sheiserman
It is disappointing.
I should have an oil bath off an old Case DC if you think that could be crammed in there....
4
https://www.amazon.com/gp/product/B000C ... UTF8&psc=1 is the K&N filter I bought off Amazon. YIKES the price has gone up by thirty bucks since I bought it a bit over a year ago. Holy smokes I installed in on 3/2/22, and have put 25000 miles on her since then, without going on a long trip, just commuting and occasional club rides. Wow.
The K&N filter is for an '85-'92 Camaro, and fits inside the plastic portion of the stock air filter element. Just pull all the paper out. I didn't have to do any trimming, and I filled in the gaps around the element with black RTV. The filter hold-downs have been missing the whole time I've had Gertrude, so I used the rubber that came with the filter to fashion spacers to hold the element down.
If the foam rubber around your existing element is toast, you can use stick-on weatherstripping foam tape from Home Depot in the appropriate size.
sheiserman
sheiserman wrote: Thu Jul 20, 2023 10:50 pm
....and a brand new air filter showed up today with the two headlights that were ordered at the same time.
Return to “Forum/Classified Ads Use Questions”
