CB Radio: Is my 03 Voy. XII set up or do I need another wiring harness to install ??
- Has liked: 87 times
- Been liked: 236 times
Re: CB Radio: Is my 03 Voy. XII set up or do I need another wiring harness to install ??
03;
the harness as it is from the factory does have a power plug already installed for the available OEM Clarion CB.
However; the front clutch lever perch control/the rear passenger control are harnesses which come with the stock CB kit and plug into the stock main harness.
https://amervoyassoc.org/Documents/Kaw_ ... tInstr.pdf
See also the electrical wiring schematic for details; Section 15 of the Motorcycle Service Manual.
