1700 Engine Heat
1700 Engine Heat
I just got my Voyager back from its 3750 Service. I had them flush out the original factory coolant and install Engine Ice as per Duane Ash's suggestion. It runs much cooler and a definite differance in heat on the right side.
Re: 1700 Engine Heat
I'm glad it worked for you, but I heard that you really need to stay on top of it..Wallace18 wrote:I just got my Voyager back from its 3750 Service. I had them flush out the original factory coolant and install Engine Ice as per Duane Ash's suggestion. It runs much cooler and a definite differance in heat on the right side.
I heard that you have to check the fluid level regularly w/ Engine Ice...
Please let me know if that's true...
Well I have about 700 miles on the bike since the change to engine ice and I have not noticed any problems at all. In traffic in high ambient temperature the gauge still goes up till the fan kicks on. But once underway the bike runs much cooler. My wife even noticed the differance from the back seat. So far so Good!
- dapasda
- Current bike(s): 2006 Harley Electra Glide Classic
Here is the Engine Ice website, showing their distributors.
http://www.engineice.com/distribution.html
Screws fall out all the time, the world is an imperfect place. (John Bender)
You see, we're not "The Wonders" right now. We're "Cap'n Geech and the Shrimp Shack Shooters". (Lenny)
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
I believe I have seen engine ice at some of the local auto stores here as well.
Iron Butt Member #47339
- Top K
- Current bike(s): '09 Kawasaki Voyager ABS
'06 Suzuki C50T - Location: Aylett, VA
The best solution I found to get the bike cooler is a little more pricey than replacing the coolant, but the benefits justify the added expense. I installed an Air Kit from Thunder Mfg along with a Fuel Processor by Cobra (as well as a set of Cobra Tri-Oval Slip-Ons). A Fuel Processor alone will make your engine run cooler - couple that with more air (Air Kit) and you will be amazed how much cooler the bike runs! Not to mention the increased performance - it's just a win-win situation.
'09 Kawaski Voyager ABS
'06 Suzuki C50T
USMC '77-'99
'06 Suzuki C50T
USMC '77-'99
- Been liked: 81 times
Cycle Gear has Engine Ice on sale until the end of May here in CA. Which means that Cycle Gear carries Engine Ice.
