HMB Don wrote:There was a tech tip in the Voyagers Voice about the antenna from a Victory MC that is a direct bolt on to 1700 Voyager. It's from J & M audio #VAS-100, I've got it on my Voyager 1700 and it's the same height as the Radio antenna.
There's good info in the Voyagers Voice magazine, but you have to be a AVA member to receive it.
Good Luck
Thanks Don for the come-back, and the info on the Victory M/C. If I understand you correctly, you went with a shorter CB antenna to match the AM/FM radio antenna? If so, did that affect your SWR's on the CB? Being that SWR's are set by lowering or lengthening the antenna. When I ordered my CB, I got it as a package with antenna pre-set to radio on SWR's, so I wouldn't want to change the CB antenna, just the AM/FM antenna, so as not to affect the SWR's on the CB.
Anyway, once again, thanks for your help on this. GOD Bless, and stay safe out there!
Keto
