Cruise control not working
- Current bike(s): 2009 Voyager 1700
Asking for some help diagnosing problem with Cruise Control not working on 2009 Voyager 1700. The orange light comes on, however not able to get it to set. No Green Light. Any suggestions greatly appreciated.
Thanks,
Steve
Thanks,
Steve
Steven and Karen Tennant
2009 Voyager 1700
Columbus Georgia
2009 Voyager 1700
Columbus Georgia
- David (N. Alabama)
Re: Cruise control not working
Hey Steve. Sorry to hear about your cruise not engaging.
Do you have a service manual?
- Current bike(s): 2010 Kawasaki Voyager 1700 ABS
Sounds like a Dealer item to me. The orange light would indicate power but not engaging may mean some electrical hicky from the switch out.
Courage Is Being Scared To Death, but Saddling Up Anyway. John Wayne
2010 VV ABS Blue/Silver (the fast one)
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
If your bikes still under warranty, which I believe it might be, let the dealer deal with it.
Iron Butt Member #47339
- RodWestphal
- Current bike(s): 209 VV1700
2008 Concours14 - Location: Alamogordo, NM
That is right, it is a warranty item. However there are a couple things that will keep it from engaging. There will be a switch on the front and rear brakes plus one on the clutch. If any of them is showing the brake / clutch is engaged it will keep it from engaging the cruise.
Good luck and let us know what the problem is.
RR
RR
RR
Have Motorcycle Will Travel
2009 VV1700
2008 Concours14
2009 VV1700
2008 Concours14
The service manual has a step by step process for determining where the problem might be. This bike is pretty smart. It will provide fault codes when you put it in test mode to help you diagnose the problem. It is in the electrical section of the service manual. This way you will know what the problem is before bringing it to the tech and see if they come up with the same result.
Thanks David for your help. It is showing fault code 2 which is front/rear brake cancel switch. I spent a couple of hours working on it last night with no luck. I will be taking it in to the dealer for warranty repair on Monday and will give follow up when it gets fixed.
Thanks,
Steve
Thanks,
Steve
2009 Voyager 1700
Columbus Georgia
2009 Voyager 1700
Columbus Georgia
local dealer found problem to be in the setting switch. new switch and works great. All under warranty.
2009 Voyager 1700
Columbus Georgia
2009 Voyager 1700
Columbus Georgia
That's very interesting. The test showed something different than what was replaced.steve wrote:local dealer found problem to be in the setting switch. new switch and works great. All under warranty.
I'm glad it was fixed Steve.
