A New iPod
- Current bike(s): 2012 1700 Voyager ABS
A New iPod
I just bought a new 2012 Voyager and purchased the iPod cable set. Plugged my older iPod classic and it doesn't work. The ipod is about 5 years old, do I need a newer model to interface with the bike and if so will an ipod classic or a Nano work?
- Current bike(s): 2013 Kawasaki Voyager 1700
Re: A New iPod
Strange! I have the 2012 Voyager also. I also have the older ipod and it has worked just fine. Just to be sure, it needs to be charged to work. I found this out the hard way. I thought if you just plugged it in it would start right up. NOOO. Took several min.s of riding to charge it back up. If the ipod is working off the bike it should work with the bike. Good luck!!
Pathfinder117
- Current bike(s): 2009 Voyager
Re: A New iPod
I have a 2009 and my iPod Classic didn't consistently work well due to the internal hard drive. I don't think it liked the bumps, but it did work after being reset. Several times reseting, I moved to a iPod Nano (not the small ones of today) which works flawlessly.
Joe Hellman
Central Point, OR
Central Point, OR
- Been liked: 81 times
Re: A New iPod
I also have an older Ipod, a hand me down from my son. The screen is broken so you can't read what's playing. But when plugged into my 1700 it works great. It did until last week when the Ipod died.
- Current bike(s): 2010 Voyager ABS
Re: A New iPod
I had a 2009 Voyager and had no problem with my older iPod. When I got a 2010 Voyager, the iPod did not work intermittently. Kawasaki replaced the cable and eventually the stereo. That did not help. I finally bought a new Nano. It has worked fine for the past year. While anything from 4th generation on should work, it is not the case. Get the newest iPod.
