bike maint.
wsm 1
Current bike(s): 1998 gl 1500 SE 2002 voyager xii
bike maint.
Post by wsm 1 »
Bike is going to shop soon ,I have done oil and rear end change,looking at brake and clutch fliud change,nrake pads front and back.Progessive springs up front ,lube all cables tune up and steering bearing.Anything else you guys can think I may need to do? :help:
Re: bike maint.
... just curious, what do you call "tune up"??? TIA
starrider
2013 Can AM Spyder RTL
1976 Time Out Camper
Been liked: 5 times
Re: bike maint.
Post by starrider »
Add check battery fluid if appropriate. Make sure speedometer cable gets lubricated. Other than that, tire pressure and lights.
Gary
wsm 1
Re: bike maint.
Post by wsm 1 »
I guess plugs,for a tune up.
starrider
Been liked: 5 times
Re: bike maint.
Post by starrider »
One other thing I forgot. A bit of lithium lube on the pins for brake and clutch levers.
Gary
Has liked: 893 times
Been liked: 315 times
Re: bike maint.
Do a search on AVA forum for ignition switch harness,and follow the checks,if you have not already done that.I would also change the shock oil,if you still have the original air shocks,I went to a 5w-20 synthetic,which made a big difference from the original. :thmup:
wsm 1
Re: bike maint.
Post by wsm 1 »
Thanks ,I going to change to Progressive shocks on front ,all ready on the back.
Re: bike maint.
Tune up should always include, plugs & carb synching.
Re: bike maint.
... when it comes to tune-ups, I see a common thought is plugs...
Why not just use iridium plugs and be done with it? Appreciate thoughts.... TIA
wsm 1
Re: bike maint.
Post by wsm 1 »
Thanks ,that is what I,m thinking too.
Re: bike maint.
I have one thing you need to add, a fat wallet. :rolling:
wsm 1
Re: bike maint.
Post by wsm 1 »
:gig:
Been liked: 82 times
Re: bike maint.
After you get the bike back
Add
lube kick stand pivot bolt
Adj and lube cruse control cable (it's simple after you remove the faring)
fuel filter
diff fluid change 180cc
You'll be ready for a couple of years of riding!
