We rode over 400 miles on the bike this weekend, with the TPMS in place. Here is what I learned in riding with it, long distance...
The front tire was fine, its temperature remained below 100 F, and its pressure from cold (41 PSI) only ran up to 44 PSI. Neither alarm for this tire went off.
The rear tire went from 41 PSI to 50+ PSI, hot! The alarm works. I dropped the pressure in the rear tire to 39 PSI, cold, and I adjusted the alarm threshold on the pressure up to 50 PSI. On the second day, the pressure ran up to 49 PSI, and the temperature on the rear tire reached 105 F (default alarm threshold is 150 F?), but it was stable thereafter. The tire pressure behavior was a little strange, but there were numerous variables involved. Time will tell if it was a fluke, which I suspect it was. It was interesting to see the dynamic differences between the front and rear tires, under load, at highway speeds (55-75 MPH), with a heavy load on the bike.
My biggest take-away from the TPMS system has nothing to do with the TPMS system at all -- it is the tires that truly impressed me! We have ridden for years, with sketchy tire pressure corrections/monitoring, and yet, they never failed, other than one inner tube blowing out (
EDIT: 1979 Honda, back in 2010; mechanic said it was a factory defect, a week spot which gave out -- I believe he was correct). The modern motorcycle tire is quite a marvel of engineering, IMO.
On day 2, Sunday, for the 200-mile+ ride home, the pressure seemed to peak at 49 PSI, for the rear, while the temperature hit the usual 100-105 F. No alarms, no issues, whatsoever.
I did manage to forget the locking wrench for the Sensors at home... I used my mini-Leatherman tool's pliers to loosen the locking nut, so I could bleed off some pressure on the rear tire. I then tightened it back up. Made it home without losing the Sensor, so it must have tightened properly.
The display was fairly easy to read while riding. It is not super-bright, but typically bright enough. The temperature readings are quite small, and they are an orange color, so they are more challenging to read, but it can be done, with a little squinting -- on a straightaway, with light traffic.
My real concern was that I find it tedious to check the tire pressure. I had a 90-degree valve stem installed on the rear, which helps. It seems easiest, and best, to pull the left saddlebag, to read the pressure on the rear tire, and that is a hassle. I do not enjoy getting on my hands and knees, anymore. That faded with my youth, sorry to say. This inexpensive TPMS system will allow me to stay on top of tire pressures, which is critical from a safety standpoint, as well as extending the longevity of the tires -- more miles before I need to put new skins on.
out of five
I also put the correct amount of
Ride-On in each tire, before the trip. Gotta say, I am sold on this stuff. Auto-balances each tire, on each ride, dynamically. Perfect balance every ride, without muss, without fuss. Great product, as well. Worth every penny.
Anyway, I thought I would post my experiences and thoughts for those viewers who might wonder how they ride. Cheers!
