LOWER AIR BOX installation clearance issues
Sci_
Current bike(s): 2001Kawasaki Voyager XII
1982 Harley FLT
1997 Harley FLHP
1993 BMW K75
2009 Yamaha XT250
Has liked: 7 times
Been liked: 6 times
Post by Sci_ »
Morning guys,
I have a 2001 XII and recently replaced the O-rings on the fuel rail and reinstalled the carbs but I’ll be dam if I can’t get the black LOWER AIR BOX back in between the carbs and the frame. I’ve tried pushing , pulling and twisting from both sides but it seems I need another 1/8” clearance. I have done it before years ago but can’t remember how I did it. Can someone clue me in?
Thank you,
Sci
Has liked: 243 times
Been liked: 633 times
Re: LOWER AIR BOX installation clearance issues
I put the carbs in last, between the boots.
Sci_ (Fri Apr 19, 2024 9:06 am)
Conrad
89 yamaha venture royale
Has liked: 27 times
Been liked: 62 times
Post by Conrad »
When i did my carbs, i took the whole back of the bike apart like the manual says. Lower airbox still a pain, but prolly a little easier. But a big pain taking the whole back of the bike apart.
Sci_
1982 Harley FLT
1997 Harley FLHP
1993 BMW K75
2009 Yamaha XT250
Has liked: 7 times
Been liked: 6 times
Post by Sci_ »
Nails wrote: Thu Apr 18, 2024 3:37 pm I put the carbs in last, between the boots.
Thanks Nails.
Sci_
1982 Harley FLT
1997 Harley FLHP
1993 BMW K75
2009 Yamaha XT250
Has liked: 7 times
Been liked: 6 times
Post by Sci_ »
Conrad wrote: Thu Apr 18, 2024 5:19 pm When i did my carbs, i took the whole back of the bike apart like the manual says. Lower airbox still a pain, but prolly a little easier. But a big pain taking the whole back of the bike apart.
My factory service manual is very poor and lacking when it comes to removing the carbs. It has two lines; remove air cleaner housing, remove carburetors. peeve poor. Guess I will take the carbs off again and get that air box in first.
Been liked: 108 times
I replaced my carbs on my bikes several times. I never remove the lower air box. I just remove the bolts and pry it aft to get the carbs out and same with putting them back in.
Stew (Fri Apr 19, 2024 6:39 pm) • GrandpaDenny (Fri Apr 19, 2024 11:54 pm) • Sci_ (Sat Apr 20, 2024 10:01 am)
Rating: 33.33%
Sci_
1982 Harley FLT
1997 Harley FLHP
1993 BMW K75
2009 Yamaha XT250
Has liked: 7 times
Been liked: 6 times
Post by Sci_ »
Thanks for the tip Voy. I am going to add a side note to my factory manual.
Sci_
1982 Harley FLT
1997 Harley FLHP
1993 BMW K75
2009 Yamaha XT250
Has liked: 7 times
Been liked: 6 times
Post by Sci_ »
VoyKimmer wrote: Fri Apr 19, 2024 6:26 pm I replaced my carbs on my bikes several times. I never remove the lower air box. I just remove the bolts and pry it aft to get the carbs out and same with putting them back in.
*That should be added to the Tech Center Tech Tips. Very good time saver.
