1996 Voyager 1200
- Current bike(s): 1996 Kawasaki Voyager zg 1200
1996 Voyager 1200
I have a 1996 Voyager 1200 and it's not getting any spark in the number two or number 3 cylinder I changed the spark plugs today and it didn't help what should I do
- Has liked: 242 times
- Been liked: 632 times
Re: 1996 Voyager 1200
Search on "no spark on cylinders 2 and 3". Sounds like a bad coil.
- GrandpaDenny (Wed Mar 05, 2025 11:48 am)
I'm new to the Kawasaki voyagers is it one coil that runs those two cylinders or on that year is it four separate coil ?
- Been liked: 250 times
One coil per two cylinders, just like Honda, and other bike makers did, on their four-cylinder engines. Wasted sparks jumped on the exhaust cycle, without harm or ill effect on the engines. Far cheaper, less complex, than using four coils, two of which did nothing during their exhaust cycles... Cheers!
Or it could be the coil is not connected /
not common for any wiring to just come undone. How did all this start ? Was it not started for some time or did it just start acting up and not running right ? Were you working on something else Was it running fine the last time you rode it ? Does it sit outside most of the time ? Its not that easy to just get to the positive side of the coil with a test lamp
So I got into where the coil connects to the wire and it was just disconnected , it must have jostled off somehow
Now I have another problem. I was changing my headlight and arc. Some wires somehow, and now my cigarette lighter and my radio has no power and I change the fuse in the fuse box. What else could it be?
- Has liked: 904 times
- Been liked: 316 times
Did you check all the fuses in the fuse box about the air cleaner?
- Has liked: 510 times
There are also two fuses behind the headlight.
- Been liked: 108 times
And there is a relay for the headlight behind the headlight that you might have fried.
- Been liked: 284 times
Athough rare it's not surprising as they only give you a couple mm free play in the wiring.Kensleysdad8722 wrote: ↑Sat Mar 22, 2025 6:57 pm So I got into where the coil connects to the wire and it was just disconnected , it must have jostled off somehow
