92 voyager, has anyone found an aftermarket replacement ignition coil?
teteague
Current bike(s): 1992 Voyager 1200
1977 KZ1000
1981 Honda GL500 Silverwing with sidecar
1982 KZ550LTD
1996 Honda ST1100
2001 Indian Spirit
Has liked: 4 times
Been liked: 5 times
Post by teteague »
Good morning folks, I noticed on my new Me 1992 voyager that I had a slight stumble to it, I started checking the plug wires in the resistors and the plug conditions and found out that number three was not firing properly. I remove the coil and the coil wires and noticed that there was oil on the end of the number three coil wire where it went into the ignition coil. I suspect the coil is going bad and that is my issue, has anyone found an aftermarket coil that works for these bikes. Any would be wonderful. I have ordered a used one off of eBay but would love to have a brand new one while I have the bike torn apart
Thanks Terry.
Has liked: 240 times
Been liked: 624 times
Re: 92 voyager, has anyone found an aftermarket replacement ignition coil?
Yes. If you search here, you should be able to find posts with sources, specs, and discussion. I anticipate replacing my coils also.
