Trailer wiring V12
Trailer wiring V12
I am building a trailer (Harbor freight/cargo box special) and I was wondering what others are doing for wiring on the Voyagers? Are you guys running a 5-4 converter like the Hoppy 46255 or are you adding additional lights to the trailer? Any input and pro's/con's would be appreciated. Thanks.
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
Re: Trailer wiring V12
Did you try a search of the old forum, I think this discussion was done there with some connection tips. Or, of course, someone can respond here. I know the search on the old forum is a pain, but you might find it in the first few pages.royalnine wrote:I am building a trailer (Harbor freight/cargo box special) and I was wondering what others are doing for wiring on the Voyagers? Are you guys running a 5-4 converter like the Hoppy 46255 or are you adding additional lights to the trailer? Any input and pro's/con's would be appreciated. Thanks.
Iron Butt Member #47339
I just did mine in January. I used a Hoppy 5 to 4 flat converter. The major problem I had was that someone had been "there" before me and the wires on the bike were not all the right colors.
I just used a test light to find the correct wire on the bike and then wired them into the proper wire for the converter. Very simple if you use the test light and make sure you have a good ground on trailer.
Someone around here used a 6 wire plug so he has extra hot wires for the trailer. One for a interior light, another for a power accessory plug in the trailer.
Many folks also convert the lighting on the trailer to LED lights for a much lower power draw than conventional lighting.
- Chris near Kansas City
I decided to just add lights instead of using a converter. Sidenote: we actually had a Ford Escape in our shop a couple weeks ago that had one of those converters on it. Tail lights weren't working. Converter had gone bad.
After pulling the trailer for a while, I converted all the bulbs over to LED (on the trailer). Before, I could tell there was a drain on the bike's electrical system because of how much slower the blinkers blinked. After changing the bulbs over to LED, there is no difference in blinker speed with or without the trailer hooked up.
Trailer Wiring
I built a Harbor Freight trailer a couple of years ago and topped it with an old Sears cartopper cargo pod.
I used a converter form NAPA so I could also pull the trailer with my truck. By the way, the kit I used came with a 3 foot extension cord so I mounted the plug under the trunk on the bike. This keeps it clean and dry and theres no way to drag it like I have seen some others do from time to time.
Stan
Stan
Changing bulbs on trailer light to LED bulbs
I would like to change the tail light bulbs on my motor cycle trailer to LED bulbs . I used a 4 wire converter when I wired my bike and have just two lights on the trailer. I bought some red LED bulbs and replaced the original bulbs with the LED's. The running lights were poor, and when I put the signal lights on, I could barely see them. Did I buy the wrong bulbs?
Thanks, ride safe!!
Thanks, ride safe!!
With LED replacement bulbs it is very important to pay attention to which way the LED's are facing. Your LED bulb when installed should have as many Individual LED's facing the lense as possible. Also it is important to buy the same color LED's as the lense you are trying to illuminate. I think that the 1157 bulbs I bought had 24 LED's and the 194 bulbs had 5 LED's. My lights are now brighter than they were with the stock bulbs.....
- flip18436572
Here are the type of 194 LED's I purchased. I will look for the 1157 bulbs I purchased.....
Click Here For ebay Link
I forget how much I paid for mine. There are more places than this to buy them. All I can say is be patient and look around for the best deal. I purchased mine on Ebay but not from this supplier.
They do work very well though. I have more lights on the bike than ever before as you probably know, and they are brighter, and my alternator is charging better than it was stock. Plenty of room left for more accessories.....
- Rhinestone Kawboy
LED Supplier List
There is a special LED lighting links special on the AVA Related Links page. Some are retail, some are wholesale.
http://www.superbrightleds.com/carbulb-notes.htm
I went with the 24 LED for the tail lights on my trailer, and the lower rear fender. Can't remember what I put in the rear turn signal on the trailer, but went with the WLED x5 wedge base for the running lights. The WLED x5 has 4 radially mounted LEDs. Actually, hold on a sec....
I knew I had a picture somewhere. The 24 LED has 18 lights the shine out the back and 6 lights that are radially mounted. You can see a couple of the radial lights on the back side of the circuit board. Thought about the 30 LED, but didn't know if I had room in my housings for them.
Is it as bright as a regular bulb? Probably not, but I can always add more an still not reach the amount of draw on the system as before, and that was the whole point in converting over. I did buy a couple of the 194 with the inverted cone on the end but I don't think they worked as well as the WLED x5 bulb.
- Has liked: 95 times
- Been liked: 155 times
Re: love those picture
Garry I believe the picture was to serve the purpose of showing what the LED lights look like and positioning of the LED's them selves, as the LED's do vary depending on the application needs. Some are pointed straight outward while others are at 90 degree angles, and then the type shown in the picture above with radiating lights around the edge as well as straight. These would help to illuminate the entire light assembly and in some applications where a lens wraps around a corner would guarantee that the light is shown/seen in all directions.garry wrote:like a picture tells me what to look for
If there is something that you are looking for, just ask and someone will assist.
You catch more bears with honey than what you will using vinegar!
Funny, I thought that the website address and model numbers of bulbs included in the 3 paragraphs would have told you that.garry wrote:like a picture tells me what to look for
Maybe he was looking for a specific type of bear?Scott-(Altoona, PA) wrote: You catch more bears with honey than what you will using vinegar!
Harbor Freight Trailer and Hoppy Converter
I am currently using a Harbor Freight trailer with the Hoppy converter.
I had to have my alternator modified to 55 amps to handle the additional load caused by my trailer and running lights. In addition, I lengthened the tongue 10 inches to make it tow better.
- biker4life
- Current bike(s): 2000 Kawasaki Voyager XII
i've been wanting to upgrade my alternator to 55 also but cant find someone local in nyc who will do it. where did you get yours done at and how much did it cost. i have put alot of led lights on and am in the process of hooking up a trailer and i believe i could use the extra output. i notice my lights dim a little now whenever i hit the brakes .
