GPS mounts
- Lance McCaw
GPS mounts
Anybody got pictures of how they have there GPS mounted on the 1200. I am trying to decide what mount to buy for my garmin nuvi 50.
- debron
Re: GPS mounts
No picture, though I could get one in a day or two. I bought a motorcycle-specific handlebar mount for my gps model on eBay. About $15 as I recall. I removed the plastic decorative housing that sits over the ignition key/handlebar risers and mounted the gps in the center of the handlebars. Works great, easy to see and out of the way.
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
Re: GPS mounts
I used a Ram mount on mine. Don't have a pic right now, but it works great. I mounted the power outlet in the right fairing pocket.
Iron Butt Member #47339
Re: GPS mounts
- Lucasind
- 12
- Has liked: 203 times
- Been liked: 72 times
Re: GPS mounts
...nice set up Mr jensee ! easily removed when not touring !...
- Lance McCaw
- debron
Re: GPS mounts
The RAM mount is the classy but spendy way to go. I went simple (cheap) with a handlebar clamp-on:
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Re: GPS mounts
I mounted mine to the top on the cruise control using the mount off the bean bag for the car, used screws and double back tape to mount it, works great and is easy to see while riding.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
01 XII-sold
07 Vulcan Nomad
- Lance McCaw
Re: GPS mounts
I don't want to spend a lot of cash either. I also like things being centered any time they can be. I also bought a 12 volt female plug to mount somewhere for power. Is that what you others ues or do you cut wire and go to batterydebron wrote:The RAM mount is the classy but spendy way to go. I went simple (cheap) with a handlebar clamp-on:
- mountainman
Re: GPS mounts
Mine is Mounted above right speaker housing. Mount is a RAM fixed permanently. No vibration and it is under windshield for the surprise showers. Cord is Permanently attached and retracts into dash when not in use. Mount cost about 15.00
1982 Suzuki GS750TZ (sold)
1977 Kawasaki KZ650 (sold)
1974 Kawasaki KZ400 (sold)
Re: GPS mounts
My bike had a 12 volt car plug mounted in the left pocket when I got it. It is also where I store the mount when not in use.
- debron
Re: GPS mounts
I have a "cigarette lighter" style 12V outlet mounted as such:
- Lance McCaw
Re: GPS mounts
I bought the same one. Yours is mounted just like what I was thinking.debron wrote:I have a "cigarette lighter" style 12V outlet mounted as such:
- richardb, austin
Re: GPS mounts
And don't forget the raincover. If it's a 3x5 Garmin, you can repurpose a Listerine bottle.
richardb, austin
__________________
__________________
- 12
2003 Kawasaki Concours (Motorcycle Heaven) - Location: Boise, Idaho
Re: GPS mounts
I mounted mine on top of the cruise control and drilled a hole to hold the mounting screw. I ran the wires from the GPS unit under the cruise control and directly to the battery for power and have a 5-amp inline fuse in place for circuit protection.
Carrier take-offs and landings... The best 2-second rides of your life!
- Lance McCaw
Re: GPS mounts
I put my plug in behind the cover on the left side. Cant see it unless its in use. For my GPS mount I bought a RAM mount for $38.00 and I love it.stubabe wrote:I mounted mine on top of the cruise control and drilled a hole to hold the mounting screw. I ran the wires from the GPS unit under the cruise control and directly to the battery for power and have a 5-amp inline fuse in place for circuit protection.
