Cassette keeps switching sides it seems?
KISSfanJoe
1984 Honda V65 Magna
2002 Victory V92
1984 Kawasaki KZ 1100 LTD
Post by KISSfanJoe »
Hey everyone,
In messing with the Voyager today, I noticed that when I put my 3.5 adapter cassette in and plug in the iPod it seems to be switching sides or something. Basically I will get like 3 seconds of play, and then it will go off for 3 seconds, then the sound will come back for 3 seconds and so on... It worked fine a month ago, and has been stored in the garage since then with the exception of one night outside, but it was covered... Any thoughts? Hopefully Paul will chime in! :help:
Re: Cassette keeps switching sides it seems?
Pete's the guy to talk to about that :thmup:
Furchin
Post by Furchin »
Mine will also do that at times. Most of the time I just eject it a few times and it will start working correctly after that. You could try spraying the adapter with a head cleaner too.
'96 Kawasaki Voyager
KISSfanJoe
2002 Victory V92
Furchin wrote:Mine will also do that at times. Most of the time I just eject it a few times and it will start working correctly after that. You could try spraying the adapter with a head cleaner too.
I did exactly that! I ejected a few times and it eventually started working correctly. I will probably run one of those head cleaner tapes in it and spray the adapter with head cleaner as well. It might just be gummed up a bit from use! Thanks!
suzib6sw
Tourer
Tourer
Post by suzib6sw »
The Reason for the switch back and forth is typically because the tape has tightened up inside the cassette.. You can help it by either winding it with a pencil from one end to the other, or if you grab the cassette in both hands, and very gently flex it , that sometimes slackens the grip of the cassette case on the tape..
However, its also a sign that that larger of the two belts is stretched and cant pull the tape correctly and can lead to the tape getting chewed up..
Time to take the radio out for upgrades ;-)
Pete
1986 Voyager XII
jek7galo
Current bike(s): Kawasaki ZX-12R - 2000
Kawasaki Voyager XII - 1995
Post by jek7galo »
On my bike doing this with interval less than 3 seconds, above 50 and sometimes 90 miles per hour. whatever the radio and cassette. :help:
Kawasaki Ninja ZX-12R - 2000
suzib6sw
Tourer
Tourer
Post by suzib6sw »
jek7galo wrote:On my bike doing this with interval less than 3 seconds, above 50 and sometimes 90 miles per hour. whatever the radio and cassette. :help:
Yup.. its the belts or the take up and rewind spools are not turning..
Radio out Im afraid..
Pete
Pete
1986 Voyager XII
jek7galo
Post by jek7galo »
but this problem appears in am / fm also only occurs in acceleration speeds.
Slow down ou stop the audio is normal.
jek7galo
Post by jek7galo »
I changed the belt once, They are new and the cassette player running very well.
The problem corresponds to speed, a sensor, I do not know.
suzib6sw
Tourer
Tourer
Post by suzib6sw »
[quote="jek7galo"]I changed the belt once, They are new and the cassette player running very well.
Ok , if the belts are on correctly (The larger belts has to be threaded correctly, the picture is more or less correct even though its broken,) Then the moment sensors are the tiny little glass reed switches which you can see in the long slots..
Also make sure the switch is actually moving fully.. Its under the small PCB...
I have seen the lever out of the white square before now
Pete
1986 Voyager XII
jek7galo
Post by jek7galo »
This photo is old, the radio is installed on the bike. I'll make a video with audio cutting to post here
suzib6sw
Tourer
Tourer
Post by suzib6sw »
jek7galo wrote:This photo is old, the radio is installed on the bike. I'll make a video with audio cutting to post here
Check the screws holding the cassette to the chassis too.. If they are too long (Original were short and silver) then they will foul the mechanism and do the same thing..
Pete
1986 Voyager XII
jek7galo
Post by jek7galo »
Good, I remember that are short, but, I go do check this. :thmup:
suzib6sw
Tourer
Tourer
Post by suzib6sw »
jek7galo wrote:Good, I remember that are short, but, I go do check this. :thmup:
If all else fails, I do have PLENTY of Cassette Mechanisms..
Pete
1986 Voyager XII
jek7galo
Post by jek7galo »
Even going on the problem listening am / fm, you believe that there may be trouble in the mechanism?
You have a complete radio with the upgrade (mp3 bluetooth) to sell?
suzib6sw
Tourer
Tourer
Post by suzib6sw »
jek7galo wrote:Even going on the problem listening am / fm, you believe that there may be trouble in the mechanism?
Ok, it sounds like there is a problem with the Logic boards.. The Tape button throws a relay that disconnects power to the motor mech..
I would much rather work on your system as you know its condition.. I dont have any pre-modified to sell and working on yours will be cheaper than buying a non modified refurb
Call me 540 391 0884 till 8pm easterm
Pete
Pete
1986 Voyager XII
jek7galo
Post by jek7galo »
Obrigado Pete, But I dont speak english yet, but read and write with small help of google sometimes :gig:
I have the mp3 adapter with SD card for cassette player.
The radio not turn off , only cut sound for 1 second , return after1 second , cut sound for 1 second , return more 1 second when the bike is over 50 ~ 60 miles.
Have days that no show this problem and play the all travel without fail.
