ANTIFREEZE LEAK?
ANTIFREEZE LEAK?
I own a 2003 voyager and from time to time when running and stop and go driving, I smell antifreeze burning. The bike has 87,000 miles and I've looked at hoses/connections and I can't find anything. Any suggestions? The antifreeze level seems like it's holding steady.
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Re: ANTIFREEZE LEAK?
I've had that too!!!! you should put this in the Gen XII section, more people would see it there. I don't know where my smell comes from but I have just changed all hoses on my 88, what a pain, didn't see any signs of a leak and coolant was full before I drained it.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
01 XII-sold
07 Vulcan Nomad
- debron
He can't put it there, he's not a member.gearheadfla wrote:...you should put this in the Gen XII section, more people would see it there...
I was told to check the crossover tube in the front of the motor/base of the cylinders. Mine was leaking antifreeze from the o-rings. I'm replacing the two lower hoses and o-rings. Costing me around sixty dollars in parts. You have to pull the radiator to get to the crossover tube.
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Oh yeah, you gotta pull the radiator, I just changed every hose on my bike last weekend, that was fun.
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
01 XII-sold
07 Vulcan Nomad
- doug of so fla
When the antifreeze leaks out it usually finds a hot engine or exhaust pipe to turn it into the vapor you smell which makes no trace of the leak. The most common antifreeze leak is at the cooling manifold and if you check the flat part of the engine under it, either just before you start it or within 1 minute of running you may be able to see it there. You will need a flashlite and look in both sides of the engine, or fold a paper towel about 1 inch wide and leave it under the manifold over night and you may see fluid. When it warms up it may expand and close the leak. I have moved the manifold slightly and stopped the leak but I think that was a rare one. Also if it is coming out of the waterpump weep hole you need a new waterpump.
- joelcolletti
- Current bike(s): 1994 Voyager XII (purchased new from California Kawasaki's showroom floor)
- Has liked: 7 times
- Been liked: 7 times
I think I may need a new radiator core, but they are pricey. Any suggestions, or will I have to bite the bullet?
Miles of Smiles :0)
Miles of Smiles :0)
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Call Carl Leo 1st, his contact info is on top of forums. Then E-Bay is loaded with them used.
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
01 XII-sold
07 Vulcan Nomad
- joelcolletti
Thank you. He's on my speed dial, and even have Ebay's Voyager page bookmarked. Great suggestions - TY for the quick response :0)gearheadfla wrote:Call Carl Leo 1st, his contact info is on top of forums. Then E-Bay is loaded with them used.
I saw your post about the manifold, and am wondering where that is located? Are you talking about the area between where pipes and cylinder heads meet? I guess I should look in the Repair Manual, as I'm probably going to have my nose buried in it if It turns out that I need to replace the radiator.
Thank you.
Miles of Smiles :0)
Miles of Smiles :0)
- doug of so fla
Yes, the coolant manifold is between the front of the engine and the exhaust pipes, you can see it by looking in thru the lower fairing side air vents on either side just past the horn it is a round alum looking tube goes from one side of engine to other.
- joelcolletti
Good news: I changed a C clamp on the coolant return hose that wasn't taking to tightening. Could have happened as far back as my last coolant change 3 years ago. I used a very heavy hand mechanic is Burlingame. Same person also over filled my oil change and didn't drain the front plug either. Then he told me not to come back again.
Anyway, looks like I may be getting off cheap with a $4 1/2 inch clamp from Ace.
Drove it for a half hour today, and the temp was fine - at first heavy bar, fan didn't come on, no leaks detected, and core was bone dry. I'm hoping I isolated it to just this problem and that it will be dry again tomorrow. I'll drive it again, and if she stays dry, I'll button 'er back up. Garage floor is still dry. :0)
Carl has a good used core in the event I need one, but I'd probably want a new one.
In any event, I hope I dodged a bullet as Carl said that it's uncommon to have a radiator issue with my low miles.....
If the coolant leak stays resolved, looks like I should be able to make our NorCal Club Meeting as planned.
Still looking forward to replacing those O rings and hoses this winter. But I don't want to get ahead of myself.
Thanks for posting back,
Joel
Joel
Miles of Smiles :0)
Miles of Smiles :0)
- joelcolletti
I guess I got over excited yesterday. This morning the core and floor appeared to be dry. Then I removed to radiator cap, and coincidently / or not, one of the radiator cell wall (looks like the one to the left of the droplet) started trickling clean coolant from the same area I noticed yesterday. This is a photo I took just took.
I think I'll skip the test ride today. There appears to be some damage to the lower left corner of the radiator fins, and I found some road gravel bits dropping off from that area yesterday too. Could be just another coincidence, but there was a lot of new road getting laid north of Carmel Junction Ut; and I do live on the Coast which doesn't help.
Interested in fixing this so I can make our Aug 4th meeting and group photo. Rather miss it, though, than fry the motor.
Any comments welcomed and appreciated.
Joel
Joel
Miles of Smiles :0)
Miles of Smiles :0)
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Yep, She's a leakin, is there a good automotive radiator shop in your area? If so it won't hurt to see if they can repair it, if not and it was me, I would have no problem with any used one Carl had at all.
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
01 XII-sold
07 Vulcan Nomad
- joelcolletti
Hi Jim,
Okay - Thank you for the useful and timely information. I appreciate the vote of confidence on going with a used core too. I may try contacting our local radiator repair shop as you suggested. IMO, All sage advise and very much appreciated.
Joel
Joel
Miles of Smiles :0)
Miles of Smiles :0)
Hi Joel, No wonder we could not see it when we were in Kanab, But once you have the radiator off, now would be a good time to replace the o-rings in the coolent manifold to the engine. Maybe this machine didn't have the coolent replaced at regular intervals, so look closely at the manifold for pitting in the material. Glad you made it home OK.
Good thing you didn't have as far to travel home as I did. I would have had a serious problem getting the bike and trailer home with that leak. I sure was a hot ride home. Gene
- joelcolletti
Hi Gene.
I'm waiting to hear from a technician (probably Monday) at the local radiator repair shop, and for Don to have a chance to assess the radiator too. before scrapping the core. Don and I thought we'd have till the winter to replace the O rings and hoses I purchased from Carl, last month before heading off to Kanab, but neither of us anticipated the radiator problem coming on.
In any event, I'm trying to be patient, and thank the Heavens it didn't ruin the Rally or engine. I'll pay extra attention to inspect the manifold pitting you spoke of too. I can say that as the original owner having owned it new in 94, I had this bike serviced professionally and according to the manual. But, rarely did I got good results from the work I'd paid for, with the exception of the shop that sold me the bike from their showroom floor (California Kawasaki). It was right next to Don Medina's 94 Concourse that Don bought before I bought my 94 Voyager. The technician there repaired all the San Francisco K1000 motorcycle police bikes for years, till the dealership went under. To make a long story shorter, I 'm glad I'm servicing my own vehicle with Don's tutelage, as it has been running like new till this point.
What a small World. I'm so glad that I've started using the club boards to help step up my passion and understanding for this kind of machine. I miss the 70's motorcycles that didn't have all this plastic, electronics and etceteras, as it made for much simpler repairs and easier access to component parts. Oh well, I do love this XII a lot, and will continue to keep her in the best of repairs. I'm just really glad to be home, and have the chance to correct the problem.
Thank you for posting back and giving me some feedback on the matter. I really appreciate it, and I'm really glad I had the chance to meet, dine and ride you an Marie too. You're a lot of fun to hang out with, and are full of good ideas.
Sincerely,
Joel
Sincerely,
Joel
Miles of Smiles :0)
Miles of Smiles :0)
Hello ohiojack, have you looked around the waterpump, and the coolent manifold at the front of the cyl's ?.. Also what I have seen on some bikes, that people have removed the fuel tank for fuel flt replacement, is that sometimes the overflow hose gets pinched by the fuel tank if one is not careful getting it back together. Also its not uncommon for the orings to weep alittle until the engines warmed up, on a few machines. Hope its not like Joel's bike and you have a core thats rotted away. Gene Kap.ohiojack wrote:I own a 2003 voyager and from time to time when running and stop and go driving, I smell antifreeze burning. The bike has 87,000 miles and I've looked at hoses/connections and I can't find anything. Any suggestions? The antifreeze level seems like it's holding steady.
- joelcolletti
I guess I never did conclude this story. Bike's up this year after lots of patience. It ran cool in Nevada at the Rally. I'll try to restore the photos to this post. The links were broken when I accidentally deleted them from Photo bucket. Thanks for Gene and those that read my request and helped. Much appreciated By way, Bill had some radiator concerns, but Don had him loosen his water cap, and Bill drove back from NV running just above the second heavy line. I'll try posting a couple of photos I found that a club member took at the rally. Bill said he tightened the cap when he got back home and that took care of it.
Miles of Smiles :0)
Miles of Smiles :0)
