Whine question
crash33
Current bike(s): 77 kz 1000
75 z1 900
77 kz 650
98 voyager
Whine question
Post by crash33 »
ok did a ride today and wore the open face helmet and i am hearing a Whine at 3000- 3200 rpm, its def rpm related as I dropped down a gear and hit the same noise at the same rpm.
Since I dont hear that well land cant tell direction of sound it makes it even more difficult to pin point it and it could very well have a noise at lower rpm but I dont hear it.
i did run the rpm's up in the shop when I got back and still hear it and seems like a ( not as loud ) whine at lower rpm, but not sure.
So the question would be if someone has had this noise before what was it?
My first thought on the sound was like a Alt bearing, but I cant pinpoint it for sure
Thanks for any ideas
77 LTD 1000
77 kz 650
75 z1 900
98 voyager xii
State Captain
Texas Patriot Guard Riders
jre258 in SoDak
Re: Whine question
Post by jre258 in SoDak »
I think most would agree that the whine you are hearing is normal for the XII. Some call it the Jetson's car sound. I hope you enjoy your new ride.
Jim
Has liked: 88 times
Been liked: 153 times
Re: Whine question
Meet George Jetson,
Jane his wife. Do do do do do do do.
His boy Elroy.........
Sorry, childhood flashbacks I guess!
That whine and the Jetson's analogy/description are perfect! From what I understand the sound could be attributed to the square cut gears.
debron
Re: Whine question
Post by debron »
Yep! Square cut gears. Varies among bikes. My '01 was loud at 70 in 5th, less loud but noticeable at 50 in 4th. My '95 has very little whine.
Skibou
Re: Whine question
Post by Skibou »
Best advice I got on this website about 50k miles ago was essentially: "Don't worry about it, it's normal. If it annoys you, turn up the radio." That's worked well for me.
suzib6sw
Tourer
Tourer
Re: Whine question
Post by suzib6sw »
It happens to co-incide with 55mph on most of the times I have heard it..
It happened on my 94 and i initially located it coming from the worn rear tire (Dunlop Elite II)
It was worse in corners..
So.. Replaced with Elite III .. Whine reduced..
Replaced final drive oil with Mobil 1 Synthetic LS75-90w grade.. and that fixed the wire to much more acceptable levels.. Its still there due to the Square cut bevel drive, but...
Mobil 1 in a grey bottle
Cheers..
Pete
Pete
crash33
75 z1 900
77 kz 650
98 voyager
Re: Whine question
Post by crash33 »
I understand the gear whine theory, but why is it RPM related, 5th gear at 3000- 3200 it has a whine, drop down to 4th gear same RPM but not the same speed and you still hear the whine at the same RPM.
it it possible to pull the alt off the motor and run it without any major issues?
77 LTD 1000
77 kz 650
75 z1 900
98 voyager xii
State Captain
suzib6sw
Tourer
Tourer
Re: Whine question
Post by suzib6sw »
May want to look at the Lash adjusters on the right of the engine..
Two shafts connected by a rod..
Im sure there are details on how to adjust it somewhere on here..
Pete
Pete
Lucasind
and a bunch of parts !
Has liked: 201 times
Been liked: 72 times
Re: Whine question
Post by Lucasind »
crash33 wrote:I understand the gear whine theory, but why is it RPM related, 5th gear at 3000- 3200 it has a whine, drop down to 4th gear same RPM but not the same speed and you still hear the whine at the same RPM.
If the alt rubbers are suspected, just replace them. They don't cost much, and they're easy to change out. at the very, least that would eliminate one of your concerns. :-D
mountainman
Re: Whine question
Post by mountainman »
The XII is a whiny machine! The alt rubbers will make a rattling sound no whine there. The alt its self does whine some. But so does the gears in the engine and the rear end and the rear tire if its scalloped which is inevitable.
1982 Suzuki GS750TZ (sold)
1977 Kawasaki KZ650 (sold)
1974 Kawasaki KZ400 (sold)
Has liked: 893 times
Been liked: 314 times
Re: Whine question
The primary reduction,[crankshaft to clutch],gears are straight cut.This can add a little whine and would not change in different gears as the primary reduction gears are engine speed related.You would notice the whine less in the lower gears as there would be less load on the gears than in the higher gears.Helical cut gears make almost no whine but add considerable end thrust to the shafts that the gears are mounted to.
JHD
'09 FLHT Police
'03 RE Bullet 500
'77 XS 360-2D
Re: Whine question
Post by JHD »
Chris near Kansas City
Re: Whine question
Pretty much any noise you hear in this video is normal, except the "woo woo woo wooo" from the cupped rear tire. I wish I had a video of a noisy final drive. My '90 was so bad when I first got it in '02, it made hearing the radio difficult.
crash33
75 z1 900
77 kz 650
98 voyager
Re: Whine question
Post by crash33 »
that sounds like the noise, is that what you hear from the gears?
77 LTD 1000
77 kz 650
75 z1 900
98 voyager xii
State Captain
