new horn
mikey
Current bike(s): 2003 kaw voyager 1200
new horn
Post by mikey »
i'm not a Electrical engineer and don't know much about it, but i would like to buy a new horn and louder one. what i need to know do i have to use a relay and why or can i just use the original horn button :Cball
thanks for your help :please:
davidl
Re: new horn
Post by davidl »
Yes, you do have to use a relay for a "bigger, heavier" horn. and yes you can use your horn button/wire to trigger the relay. If you don't use a relay, you will blow the fuze everytime you try to use the horn.
mikey
Re: new horn
Post by mikey »
thanks now i understand :clap:
Been liked: 249 times
Re: new horn
I would suggest adding in an additional fuse block to supply power to the new horn directly from the battery. I would also suggest adding a 12 Volt accessory outlet (for cell phone charging, GPS, etc.) at the same time, wired through the new fuse block, with a relay powering it, through a switched circuit (one that is off when the key is off). Cheers!
EFC7018
Current bike(s): 2003 Kawasaki Voyagerxii
2004 Kawasaki KLR 650
Re: new horn
Post by EFC7018 »
Yea, I will be adding an accessory outlet to mine.Recently needed that for my cell phone.
