Top Rad hose removal? High idle
Tonyvdb
1981 GPZ 550 (Previous bike)
Post by Tonyvdb »
Ok, so I got all the correct hoses in for the cooling system. How does one get at the clamp that connects the top rad hose to the thermostat under the battery? The clamp screw is facing down so I cant reach it from where the battery tray is.
Has liked: 893 times
Been liked: 315 times
Re: Top Rad hose removal?
Does the clamp screw happen to have a hex head, that would allow you to use a wrench on it?
Tonyvdb
Post by Tonyvdb »
it does but its facing down and I cant reach it from below because the pipes are blocking access. Its just in the worst possible location.
chevyman1
Been liked: 16 times
Post by chevyman1 »
Try removing the rear 2 hoses the fill hose and take the bolt out that holds the housing in place then with the clamp loosened on the radiator you should be able to pull the housing out or move it enough to get the clamp loose.
You might have to take the air filter box out or loosen it. :thmup:
Tonyvdb
Post by Tonyvdb »
So got everything back together and went for a ride. No leaks :) Thanks for the tips :thanks:
Now for a new problem, it now idles to high even after it warms up it sits at around 1500rpm even after the 30min ride I took. Before I replaced the hoses it was below 1000rmp What gives?
Lucasind
and a bunch of parts !
Has liked: 203 times
Been liked: 72 times
Re: Top Rad hose removal? High idle
Post by Lucasind »
....Hard to tell with out being there......but a throttle cable may be out of position from your repair,slightly pulling at the carbs,not letting the throttle actuator rest on the idle adjust stop.
If you turn the bars fully left and right it may also increase the rpm's even more. ?or choke cable?
something to check................ :-D
Tonyvdb
Post by Tonyvdb »
when I replaced the two hoses that go from the thermostat under the battery to the left and right side below the faux tank I noticed some cables connected to some sort of control. Is that the "actuator" I will have to look at that. Maybe the hose is putting pressure on it somehow?
Turning the steering makes no difference.
