I'm sure that Loren (cushman eagle) meant "the manifold o-rings"... not to replace the manifold.Now would be the time to replace the o-rings ,as they have been a issue on the XII at some point in the bikes lifetime.
Guys that have done it before,see the picture of your engine sitting on the floor with easy access to this job,as compared to when the engine is back in the bike ....................Tony
Lucasind wrote:I'm sure that Loren (cushman eagle) meant "the manifold o-rings"... not to replace the manifold.Now would be the time to replace the o-rings ,as they have been a issue on the XII at some point in the bikes lifetime.
Yes,Tony is right,I did mean just the O-rings,not the manifold While you are there,make sure the radiator is clean inside and out.
