I have a decent oil leak coming down from my water pump. Since this thing sat for a decade I'm just going to change every gasket in the vicinity: 92055D(gasket between block and pump), 11009(gasket between pump halves) and 92055B/Qty:2(gaskets for the inlet/outlet hoses.
Anything I should do while I'm already in there? I'm assuming the repair is fairly straightforward, just take off what's in my way until I get to the pump?
Thanks.
Water pump oil leak
- Current bike(s): 1989 Voyager, 2004 Honda Interceptor
Re: Water pump oil leak
... http://tinyurl.com/hbq9y4b for some "hints" , might as well plan on changing
the water and oil 'cause Ya gotta drop it... JM2C
- Has liked: 893 times
- Been liked: 315 times
Change the seal in the water pump while you have it off.Carl Leo has them.That seal is what was leaking oil on my '99
