Speedometer Correction
- 1lpdean
- 6
- Current bike(s): 1987 Voyager XII
1988 Goldwing
2007 Honda Shadow Sabre - Has liked: 2 times
Installed a speedometer gear from a 1993 Kawasaki Ninja 600R on my 87 XII and it is truly a plug and play change. I have been running it now for a week and my speed seems to be right with my GPS now. As for the odometer I have a correction factor of 1.0644. Very pleased with the results.
- These users liked 1lpdean's post:
- Bonnie and Clyde (Fri Jun 02, 2023 9:35 am)
2006 Vulcan 750
- Been liked: 58 times
- Has liked: 245 times
- Been liked: 634 times
Re: Speedometer Correction
Mine was off about 6-7% before that conversion described in the Tech section. I suspect the different cog is the same PN as described above. Note that this changes the odometer: you have a choice between accurate speedo (my preference, re. speeding tickets) or accurate odo (I also kinda like correcting my gas mileage upward).
- 1lpdean
- 6
1988 Goldwing
Nails, that makes sense. The last few trips I've checked the odometer was off right at 7 percent. Just for the record the ninja gear setup is the 23 tooth by 14 tooth.
- Bonnie and Clyde
2007 KTM Super Enduro 950
- Been liked: 50 times
My speedo is off as well, But I run a GPS that is showing actual speed with the posted speed limit. I use the odo as a fuel gauge because the fuel level and light I dont trust. I guess I choose the odo to be as correct as possible. To each their own.
It's easy to pull the fuel gage (both level and light) to check/repair. Hardest part is taking off the driver's seat.Bonnie and Clyde wrote: ↑Sun Jun 11, 2023 10:42 amI use the odo as a fuel gauge because the fuel level and light I dont trust.
- Bonnie and Clyde (Mon Jun 12, 2023 9:11 am)
