Quick Exhaust Question
- BackTrackBug
- Current bike(s): 2002 Kawasaki Voyager XII 1200cc
- Has liked: 18 times
- Been liked: 5 times
New owner to a XIi. Question about the exhaust. Its a 4 into 2 system with crossover. ( Correct me if Im wrong) well, at the rear four tips on mine I get exhaust puffing out the two outer tips but the two inner tips feel as if they are sucking air a bit. 100% of exhaust is being passed out of just the two outer tips. Is this a symptom of something wrong? Valves? 2-3 cylinder issue? Seems like the exhaust would be thouroghly mixed from all 4 cylinders before reaching the tips and would be exiting all 4 tips equally.Im kind of confused about what is happening.
- Has liked: 906 times
- Been liked: 316 times
Re: Quick Exhaust Question
I do not think the center two are open to the exhaust,but are just cosmetic.
I tried to run small piece of wire up both of my right side,and the center tip is blocked part way in .
- BackTrackBug (Sun May 07, 2023 9:13 pm)
- BackTrackBug
Interesting. I'll try the same wire trick. But I swear it feels to me as if it sucks a little air in in cadence with the engine. Very well could be my imagination.cushman eagle wrote: ↑Sun May 07, 2023 7:06 pm I do not think the center two are open to the exhaust,but are just cosmetic.![]()
- Has liked: 510 times
Yes, one tip of each pair is a dummy.
- BackTrackBug (Mon May 08, 2023 7:48 am) • dirtbike13 (Sat May 20, 2023 6:34 am)
- BackTrackBug
Thank you for clearing that up for me. Was worried something was wrong with 2-3 cylinders or something else going on.
- These users liked BackTrackBug's post:
- GrandpaDenny (Mon May 08, 2023 9:21 am)
- Has liked: 244 times
- Been liked: 634 times
I don't think it's really a dummy, just doesn't flow much at idle. The plumbing in there is complicated.
Recent Harleys are like this two: one side seems blanked out. But until a decade ago or so, those two mufflers were identical. (I still plan to fab these older Harley ones onto my XII, to grow it a pair. Unlike others on here, my XII is NOT a girl.)
- BackTrackBug (Thu May 11, 2023 9:04 am)
- 1lpdean
- 6
- Current bike(s): 1987 Voyager XII
1988 Goldwing
2007 Honda Shadow Sabre - Has liked: 2 times
Nails, did you ever get the Harley mufflers on yours? I've been contemplating the same thing.
No. I haven't even repaired a breakdown a year ago. Been super busy -- I might have to come out of retirement to get some rest.
