how to videos 4 sale
dogzz
Current bike(s): 1980 GS1000 G
1986 Voyager XII
Post by dogzz »
Is there still videos for sale on front forks? I cant find them & would like to have one when i redo my forks
Thanks
Vinny
debron
Re: how to videos 4 sale
Post by debron »
If nothing else, do a Google search on "how to install progressive fork springs" and you will find a number of videos and documents on the process on various bikes. Forks are somewhat generic to a large extent, I think.
Tat2demon
Current bike(s): 78 Yamaha XS 1100
81 Yamaha XJ650
88 Kawasaki Voyager XII
Post by Tat2demon »
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
jre258 in SoDak
Post by jre258 in SoDak »
Nate, I found that the tool used to remove faucet handles, with a little modification, works great to push down the top plug so that you can remove or install the retainer ring.
Jim
Tat2demon
81 Yamaha XJ650
Post by Tat2demon »
I actually ended up putting a 3/4" socket on the plug and ran a ratchet strap top to bottom and tightened it down. That was after trying to force it for about an hour by hand. Could get the spring compressed but couldnt hold it long enough to get a pick in there to get the ring out. Tried so hard and so long that even after a week I have still have bruises on my palms from the center hole of the socket. Looks like I have stigmata.
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
Tat2demon
81 Yamaha XJ650
Post by Tat2demon »
Oh and Carl says he does his while still on the bike. Can put a socket on the cap and use some kind of lever to go under the handlebars. Sounds like a great idea.
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
I stand on the footpegs and use a large phillps screw driver & push down and the wife picks the spring out. Those xtra hands on a XII or any MC make the job much easier. :LvStrk
debron
Post by debron »
Don Medina made a nifty little device, a triangular shape out of aluminum (???). Drilled two holes that allow it to be bolted to the forward handlebar clamp bolts, a third threaded hole positioned over the fork. Then he just screws a bolt through the threaded hole that pushes down and holds the fork spring. To do the other fork, just flip the device over.
voyager55
Current bike(s): 2003 1200
Post by voyager55 »
dogzz
1986 Voyager XII
Post by dogzz »
WOW guys great advice ! Thanks a bunch Im just a lil nervous taking the girl apart :pray: . I'll be doing new fork seals & progressive springs (back was done last year).Cant wait till spring comes in so I can enjoy the upgrade :thmup:
Thanks again
Vinny
