Then with the 4 tools you see on the shop towel, air cut -off , razor blade,file,and a skroll saw blade gripped in a small set of vice grips, the square hole was made.
The voltmeter was installed into the hole,with a dab of black permatex, around the perimeter of the backside of the meter. and returned to the left side of the fairing.
The wires were then hooked into the "keyed" accessory wires. Turned the key on and by gosh the meter lit up and read 12.2 volts ! ( I have'nt had my battery tender on it for awhile, since the winter service and updates have been happening) That's all I had time for last night, not to mention ,I heat my garage with a couple of "clean burn"
more later................................tony
