Progressive spring install
- Pbpd183
I am planning to install progressive springs on my 2000 XII. I have reviewed this forum plus the instructions on abikerboard. Looks do-able. I plan on doing the swap with the forks on the bike and use a faucet handle puller. I have a question to get me started. How to theblack plastic caps come off? Do you just pry them with a screwdriver?
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
Palm Bay, Florida
Previous
2000 Voyager 1209
- Current bike(s): 2003 1200
Re: Progressive spring install
yup, they just pop off
http://www.abbikeboard.com/jeff/spring/spring.html
Follow this guide. Easy to install
- Pbpd183
Great! Thank you.
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
Palm Bay, Florida
Previous
2000 Voyager 1209
- debron
Here's another tip: After draining the old oil out of the forks, spray starting fluid into the tube until it runs clear out the bottom. You'd be surprised how much of the old oil is still in the tubes. But don't do this while you are smoking!
- Pbpd183
HA! Great tip. I'll do that. Thanks.
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
Palm Bay, Florida
Previous
2000 Voyager 1209
- Lucasind
- 12
- Has liked: 203 times
- Been liked: 72 times
read up on it ....then 90% of the job is getting started
....you'll be done before you know it !
the results are worth the effort !
I remember a post about which way to insert the new spring and how it affected performance but I don't remember what was said. May not have affected performance but you could hear the spring compress if the tight wind was on top or quieter with the tight end on the bottom. Does anyone remember this or am I just getting foggy.
- Current bike(s): 2002 Kawasaki Voyager
2-1987 Kawasaki ZL1000
2-1985 Kawasaki ZL900 Eliminators
1985 GL1200 Honda Goldwing - Has liked: 0
Put the tightly wound coils down for less spring noise. I did this upgrade two years ago and it's been a world of difference since then. New oil does wonders too and I used 15 weight....very happy with the results.
- Pbpd183
This site is the best! Thanks for all the info. I am gaining confidence with each post.
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
Palm Bay, Florida
Previous
2000 Voyager 1209
- Pbpd183
What is the easiest/best way to remove the clips at the top of the fork after compressing the spring?
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
Palm Bay, Florida
Previous
2000 Voyager 1209
- bikerking.biz
Here's more instructions on how to do the complete job.
http://www.amervoyassoc.org/techtipsXII ... %20Springs
Biker King
http://www.bikerking.biz
WAY to much extra work & removal of items that's not necessary. Jeff's guide is simple & easy.
- Pbpd183
Yes. I agree. I do not plan on removing the forks. I was asking about the best way to remove the retaining ring inside the top of the tube. Do you use a pair of needle nose pliers or a screw driver?
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
Palm Bay, Florida
Previous
2000 Voyager 1209
- lonewolf3253
Small screw driver will do the trick. I have a small set of hook & picks from Stanley that I found to work well.
- Lucasind
- 12
Agreed..... way too much work using the Schill method. I made a post calledvoyager55 wrote:WAY to much extra work & removal of items that's not necessary. Jeff's guide is simple & easy.
"air no more " Jan.24th 2014. under general voyager XII.....took under a hour.after making the tool to depress the top fork caps..........a small pick type tool will get the circlips out easily ,after the pressure is released.....................
- Pbpd183
Sounds good. Nice to know what I'm dealing with before I rip it open. Thank you.
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
Palm Bay, Florida
Previous
2000 Voyager 1209
- chevyman1
- Board Member
- Been liked: 16 times
The advantage of removing the forks is you check everything out, Bearings, bolts on the triple tree, Brake pads, Speedometer drive, Etc.
It's also a lot easier to work on the tubes out of the bike and they come out fairly easy.
You should be able to do the springs with the tubes off the bike in an 1-1/2 hr., first time maybe a little longer.
When I clean out the tubes I use mineral spirits it is not as flammable and with the tubes off the bike you can get more of the gunk out.
- Current bike(s): 1996 voyager XII, turned into a trike by motor trike company
- Been liked: 6 times
Hi there, I have a 1996 XII that has a motor trike kit on it. Where do I get the progressive springs?
- chevyman1
- Board Member
coffeeboy4 wrote:Hi there, I have a 1996 XII that has a motor trike kit on it. Where do I get the progressive springs?
Phat Performance parts had the best price at $67.00
http://www.phatperformanceparts.com/Sea ... earch.y=12
