Rear speakers
- Current bike(s): 1989 Kawasaki Voyager 1200
Rear speakers
Does anyone have experience, (or creative ideas) relocating the rear speakers? I would like to make room on the luggage rack for a rack bag. The typical bag won't fit between the speakers in the current configuration. I'm planning an extended two-up trip and need the additional space a rack bag will provide.
Thanks,
Brian
Thanks,
Brian
- Tom(North Alabama)
- Current bike(s): 2002 Voyager II
2002 BMW k1200LTE - sold - Location: Madison, Alabama
Re: Rear speakers
Hi Brian,
Most will just remove the rear speakers completely for more bag mounting room.
Really don't hear much from the rear speakers at highway speeds anyway
'02 Voyager XII
'08 Concours 14 - sold
'02 BMW K1200LTE
'02 BMW K1200LTE
- ghostler
- Has liked: 3 times
- Been liked: 10 times
Re: Rear speakers
One thing I noticed is a placard underneath the trunk package rack that warns against putting more than 2 lbs. on the rack. I gathered that the reasoning behind that might be the rack's 4 attachment points where fastened to the 1/8 inch thick trunk lid. For a 20 lb. bag that comes out to 5 lbs. static load per attachment point under the trunk rack.Silverthorne CO wrote:Does anyone have experience, (or creative ideas) relocating the rear speakers? I would like to make room on the luggage rack for a rack bag. The typical bag won't fit between the speakers in the current configuration. I'm planning an extended two-up trip and need the additional space a rack bag will provide. Thanks, Brian
Just curious, except for light stuff like sleeping bags, has anyone had any failures carrying a rack roll bag above the trunk?
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
- debron
Re: Rear speakers
I have also just removed my rear speakers to gain the extra space. While they do add to the sound experience, it's not enough that I miss them. I use the space for a tent, a couple of sleeping pads, and other gear I want quick access to, like rain gear, the outer shell of my jacket, or clothing layers I take off/put on as the day warms or cools. Never weighed the stuff but it's probably in the 10 lb range.
If I wanted the space AND the speakers I would cut 1/2" plywood to about 5" x 8" and screw it under the rack so that "wings" stick out to the side on which to re-mount the speakers. But keep in mind you have that extra width when negotiating narrow spaces!
- Current bike(s): 2002 Kawasaki Voyager XII.
1998 Custom Harley Davidson Softail FLSTC. (Evo)
1985 Suzuki Cavalcade.
1968 Harley Davidson FLH (shovelhead) - Location: Sturbridge, MA
Re: Rear speakers
hello all, I just purchased my first Voyager and am very happy with it with the exception of the rear speakers have been removed and lost by the previous owner.I was hoping that somebody who has removed theirs for more storage would be willing to sell me them...it would be awesome if they were maroon but i dont mind getting them painted...thanks for reading my post and have a safe day
- Lucasind
- 12
- Has liked: 203 times
- Been liked: 72 times
Re: Rear speakers
sillybiscuit wrote:hello all, I just purchased my first Voyager and am very happy with it with the exception of the rear speakers have been removed and lost by the previous owner.I was hoping that somebody who has removed theirs for more storage would be willing to sell me them...it would be awesome if they were maroon but i dont mind getting them painted...thanks for reading my post and have a safe day
...Currently I'm only seeing ONE on ebay ,but keep a eye on it for awhile and you should find what your looking for before too long.
http://www.ebay.com/itm/1987-Kawasaki-V ... 69fab8&vxp" onclick="window.open(this.href);return false;
- ghostler
Re: Rear speakers
Looking at the mounting system on the back package rack to the trunk, thinking out of the box,
one could use 1/4" - 5/16" plywood or OSB board to make a rectangle that bolts to 3 mount points, then mount to it an aftermarket set of speakers. Priming wood then finishing in say Rust-O-Leum black enamel would seal and waterproof the wood and give it a pleasing look.
For example, overstock.com: Pyle 600 Watt Motorcycle Mount Weatherproof Speakers
I'm only using the speakers as an example of a possibility, this is not a recommendation for that particular speaker. If a set is purchased say in unfinished plastic, one could prime and paint to match the bike. Some auto paint stores will mix up a rattle can of spray color, if you can get your bike color matched up.
George Hostler
Clovis, NM, US
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
- Avidrider62
- Tourer
- Current bike(s): Bikeless
- krasmu
- Been liked: 18 times
Re: Rear speakers
I've been looking at this as well. I'll put the question out the forum public. How many passengers actually use those elbow rests built into the rear backrest? I've sat back there and they seem to be too high for any comfort. with that in mind, my suggestion is to make a bracket to move them forward just above those somewhere, instead moving them out wider. Because the slanted design of the speaker boxes, they shouldn't need to be moved very far to make room for a nice sized bag.
Kirk Rasmussen
Machesney Park, Illinois
- ghostler
Re: Rear speakers
Agreed, I've found that just running the front speakers when up to speed is much easier listening to than running all 4. I might just upgrade the 2 front speakers and leave the rear ones OEM.debron wrote:I have also just removed my rear speakers to gain the extra space. While they do add to the sound experience, it's not enough that I miss them.
George Hostler
Clovis, NM, US
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
