I pulled the bike out this morning and right after I fired it up the headlight went out and the front running lights are not working either. I checked the bulb, the infamous 10 plug, the fuse and the relay and they all passed. I also checked the high/low beam switch and there is no power to the switch. I'm not sure where to look next.
Thanks for your help!!!
headlight stopped working
-John-
95 Voyager XII
Past rides
85 Voyager 1300
08 Kawasaski 500 LTD
02 Yamaha V-Star 1100
96 Yamaha Virago 750
81 Honda CM400T
72 Honda CB175
Re: headlight stopped working
After further testing and research, It appears there is no power to the low voltage that turns on the relay.
-John-
95 Voyager XII
Past rides
85 Voyager 1300
81 Honda CM400T
72 Honda CB175
- chevyman1
- Board Member
- Been liked: 16 times
check the cable to the ignition sometimes the wires brake in the cover
