Screw size
voyager55
Current bike(s): 2003 1200
Screw size
Post by voyager55 »
Anyone know the screw size for holding on the plastic tank cover? 2 screws Some how lost them both.
Has liked: 88 times
Been liked: 153 times
Re: Screw size
Not sure but I removed mine a few years ago and have been running since with just the twist knobs holding the faux tank in place. Haven't had any problems or issues at all!
greybeard
Current bike(s): 98 Kawasaki voyager
Re: Screw size
Post by greybeard »
takes the same size as the other plastic I replaced mine with the screws from the left controls when I put a cup holder on and needed longer screws
Trailer...tools...small shop...tent area..hot shower and hot meal.
Re: Screw size
I think they are 6 MM I used stainless steel button head cap screws on mine
:thmup:
Lance McCaw
Re: Screw size
Post by Lance McCaw »
Most all are 6x1.00
Re: Screw size
Order yourself a metric kit with all the commonly used metric sizes. 6mm, 8mm, 10mm, 12mm etc. You will find most of the screws on metric machines will be those sizes.
ffltstn
Current bike(s): '95 Voyager
'82 KZ1000J
Re: Screw size
Post by ffltstn »
It's a screw with a collar on it so when you tighten it down you don't over tighten it and crack the cover. I go without too, but if you want to use one make a collar. Too tight and you break it, too loose and it vibrates out.
Ken
Ken In Orlando Fl.
'95 Voyager
'82 KZ1000J
ghostler
Has liked: 3 times
Been liked: 10 times
Re: Screw size
Post by ghostler »
Screw head needs to be large enough to nearly cover the recess. Someone used a smaller screw, it chipped out the hole edges. I replaced with 6mmx1 (I think that is the thread size) and flat washer that just fit inside edges of the recess. That worked. Then I went and bought the OEM screws and black plastic plug cover. Cost wasn't that much.
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
