when i pull the front brake lever,i can hear and feel the the solenoid click ,,since i took the fairing off and headlight loose,,, ,but the brake lights don't come on,,,,,,,dash lights,turn signals,running lights ,all work...can ya give me a heads up ? and what is the 3amp fuse for in the fuse box ? Thanks !!!
I appreciate any and all HelP !
So I found the blown fuse
and the brake light,,,,only trunk light brake light activates with the hand lever !!!
The foot brake does not activate brake light,,I will investigate the foot switch !!!
Does or is there a brake light on the bottom end ???
