Rider floorboards?
2006 Vulcan 750
- Been liked: 58 times
Rider floorboards?
Has anyone found some floorboards that'll fit on the bike? For that matter, since the wife will not be riding with me for 99% of the time, can the passenger floorboards and the rider footpegs be swapped without any modifications?
- Has liked: 87 times
- Been liked: 236 times
Re: Rider floorboards?
If you go to the AVA Home page, select Tech Center, then Voyager XII and then Accessories; Floorboards-Driver you can look at an installation sheet for the OEM optional driver floorboards which were made by Markland for Kawasaki and were sold at dealers.
Unfortunately they are no longer available and are occasionally seen on eBay for big dollars.
Perhaps there may be some other manufacturer making something which may fit but I don't recall any.
The Markland boards utilize the same board as the existing stock rear boards and the bracketry is where the difference comes in.
Good luck in your search,
- Chris Cochran (Sat Jan 14, 2023 11:58 pm)
- Rating: 12.5%
