Where did That rattle come from?
- Has liked: 815 times
- Been liked: 273 times
I rode the VXII to a grandsons baseball game Wednesday evening,and a rattle showed up whenever I had a light load on the engine below 2500 rpm.
No noise idling,or above 2500
It sounded like it was occurring with every power stroke(twice per revolution)
I have had that symptom on a tractor already that had a loose clutch disc,so this am I took the clutch apart,perfect,the discs were well within specs,even with 80500 miles on them.
I spent 3 1/2 hours mowing my lawn and thinking about it.
Is it possible the chain tensioner for the starter/alternator failed,so I pulled the alternator to see if the driver could be rotated indicating a loose chain .
I found the bolt holding the drive hub on the alternator came loose.
A no cost fix is something I like.
- Been liked: 78 times
Re: Where did That rattle come from?
.. I'm impressed!! Great on Ya!!!
- Has liked: 30 times
- Been liked: 134 times
Hello Loren, do you remember back when Tony took his alt out for new brush rpl.. I got so concerned about that and with another 40k more on my bike I pulled mine out........ Turned out I had same issue. Not a drop of loctite on that hub bolt , I didn't need to rpl the brush's but glad I pulled the alt out.
Gene
Gene
Cushman does that bike have a steel accessory guard on the front fender?
No,Mr.Jensee,it does not.
How are things going for you now? I sure am glad you are still on the AVA
Gene my bolt did not have any loctite on when I removed it.But it does nowekap1200 wrote: ↑Sun May 19, 2019 12:26 pm Hello Loren, do you remember back when Tony took his alt out for new brush rpl.. I got so concerned about that and with another 40k more on my bike I pulled mine out........ Turned out I had same issue. Not a drop of loctite on that hub bolt , I didn't need to rpl the brush's but glad I pulled the alt out.
Gene
Cushman: :The reason I asked was that I had a rattle on the front end of the bike that only happened when rolling. I figured out that one of the mounting points, the left side of that bracket broke and rattled loose. You had to look hard to see it but it was there. I was worried for a while that the rattle was in the fairing itself.
As for me I am doing ok. I am trying to list the bike somewhere but I need to take current pictures of it. That means backing it out of the garage and for now I am not up to it. I cut my grass yesterday. I have an electric push mower. I used to cut the front and back in about 45 minutes. Yesterday it took just under 2 hours. Between me being so out of shape my low back muscles began hurting me and my feet were really hurting. The neuropathy has affected them to the point it feels like the bottoms of them have rock bruises. But I can say I did it and also weed whacked it as well. Good thing I did because we had a storm this morning from hell that left a lot of large branches in both the front and the back. I will have to get them up because next weekend I have to go into the hospital again to have my parathyroid removed. I will have to be in there a week on a calcium drip. No fun having your throat cut and having to struggle to eat hospital food. Other than that I am fine.
- These users liked Mr Jensee's post:
- vxiirider (Mon Aug 31, 2020 11:53 pm) • Highway Rider (Sun Sep 06, 2020 12:35 am)
- Rating: 25%
- OldDC
- Current bike(s): 2003 Kawasaki Voyager xii
2006 Kawasaki Zx14 - Has liked: 0
Hello Gents,
I am shiny new here. Intersting post. I purchased a 2003 Voyager xii in June (45000 miles) knowing I had that "rattling noise" on the left side where the alternator is. I was told by a kawasaki mechanic that the low 2000-2500 rpm rattle upon releasing the clutch is a starter chain noise as a result of the bike being started with a low battery. I was planning to get it repaired this winter.......BUT let me check that alternator hub bolt first! Could it be an easy fix?
DC
DC
High,OldDC,Welcome to the AVA Forum. You obviously have found that there is a lot of friendly advice on this forum.
I hope your repair is as easy as mine was.
I now have 90,000 on the bike ,and the rattle never came back
- Barry
- Has liked: 100 times
- Been liked: 69 times
The only vxii's that have had starter chain issues that I'm aware of are the 86-87 models. They would break if trying to start with a low battery! From 88 on they are totally redesigned with double the strength.OldDC wrote: ↑Mon Aug 31, 2020 11:45 pm Hello Gents,
DC
Welcome to the forum! Lots of helpful people here. Let us know what you find.
- chicagorandy
- Has liked: 9 times
- Been liked: 14 times
OK, I'm a dunderhead, but exactly which bolt is under discussion? Here's the parts drawing for the alternator:
https://www.partzilla.com/catalog/kawas ... -regulator
Thanks in advance for making it geezer simple - lol
It is key `112 listed as Bolt-Upset 6/16
number 112 GO 616 for $ 0.86
- OldDC
Hello gents,
This is amazing information and a great starting point to do a diagnosis. I went for another ride tonight and the sweet spot for the rattle is 1500 rpm during acceleration....and then it is gone! The rattle is coming from the LEFT alternator side right on cue at 1500rpm....only on acceleration at 1500rpm..starter chain or loose bolt? Bike accelerates and works great....a hoot to ride! My "old school" Kawasaki mechanic has replaced 20 starter chains on the 1986 bikes when he had his own shop...but maybe he is wrong?..BUT as someone mentioned previously in the post, the 2003's did NOT have the starter chain issue like the '86 bikes and were make stronger.... Cushmaneagle gave a great parts diagram to look for the source of the problem. I watched a few Youtube videos with the "alternater rattle" noise in a few kz bikes at idle and read a few blogs with the same issues in kawasaki engines....and low and behold it could be that bolt being loose. A great place to start........How difficult can it be to remove the alternator and check that bolt? I will eventually give you all a follow-up on this rattle noise......
thanks gents, MrOLDDC
- Has liked: 438 times
- Been liked: 395 times
1500 rpm is pretty low to be hitting the gas for hard acceleration. Might just be lugging it. Try keeping it above 2000 rpm and see how that works. Bet she'll be much happier, and you won't hear the rattle anymore.
- Barry (Wed Sep 30, 2020 3:49 am)
- Rating: 12.5%
South Jersey Retreads
Patriot Guard Riders
Warriors Watch Riders
- OldDC
Here is a video of the the low rpm rattle on the left side of the engine? What is this low rpm rattle noise upon releasing my clutch? An old school Kawasaki mechanic told me it was the starter chain......give me your thoughts.....check out the 34s Youtube video below.....the bike runs perfect less this rattle!
https://www.youtube.com/watch?v=R36cBOBTzxM
thnaks OldDC
thnaks OldDC
Yes,OldDC,That is what my '99 sounded like with the loose alternator drive spider bolt.
An easy fix,and locktite is made to prevent that from happening again!
- OldDC
Thank you Cushman Eagle,
This is amazing and I think that you surmised your similar noise issue and repair in a previous post with the loose alternator bolt? Is it as easy as removing the alternator and securing the bolt with locktite? Can I do it myself? Simply remove the alternator on the left side and secure the bolt? Did your bike make the exact some noise upon releasing the clutch? It make sense since the alternator would turn faster with an increase in RPM's upon releasing the clutch? I do have the Voyager repair manual so it cannot be too difficult?....I just have to give it a go! I will check it out and get back to you.....thank you!
regards OldDC
regards OldDC
- OldDC
FIXED!!!!Re: Where did That rattle come from?
Hello Cushmaneagle and Voyager owners,
This post is a long time coming. I found a mechanic that replaced my fork seals and also pulled off the alternator. And there it was!! My alternator retaining bolt was broken in half! The bolt nut piece was spinning making the rattle at higher rpm (1500-1800) while the other half was still in the threads of the alternator. The rattle is gone! My 2003 Voyager sounds like a KZ bike on the the police show CHiPs! Just purrs! Unbelievable! I am elated!
regards OldDC
regards OldDC
- These users liked OldDC's post:
- cushman eagle (Tue Oct 11, 2022 12:54 am) • Bonnie and Clyde (Mon Oct 17, 2022 5:52 pm)
- Rating: 25%
- Been liked: 218 times
Congrats! I'd suggest buying your mechanic a restaurant gift card, to show your appreciation for the wonderful work they did for you. You will be amazed at how much impact such an act of thanks can have on your mechanic. A $40-$50 Gift Card will buy them, and their special partner, a nice meal and a beverage. A good bike mechanic, who is willing to work on older bikes, is hard to find -- at least for me!
I've bought the staff at my favorite small shop, gift cards in the past, to say, "Thank You!", and they were blown away. If they treat you right, be sure to return the favor. Cheers!
- cushman eagle (Thu Oct 13, 2022 12:34 am)
- Rating: 12.5%
