Need to replace my ignition switch wiring harness - have the infamous 'everything goes dead' problem that, so far, I have been able to recover from by wiggling said harness. What is the simplest way or what needs to come off and in what order to get at the harness for replacement?
Thanks,
Ohio Mike
Ignition Switch Wiring Harness - R & R ??
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
Re: Ignition Switch wire too tight
Did you check out this article first in the Tech Center/Voyager XII section?
Intermittent headlight, gauges, other.
Iron Butt Member #47339
- Ohio Mike
Re: Ignition Switch Wiring Harness - R & R ??
Thanks for the pointer Gary but I'm pretty sure this is the ignition switch harness. When it fails, I loose EVERYTHING - spark, all lights, everything. Before the time change it happened on the way to work and boy oh boy is it dark and quiet out there an hour before dawn!
Ohio Mike
Ohio Mike
Mike in Celina
03 Goldwing GL1800 / 2018 CSC Trike Kit
- Chris near Kansas City
- Ohio Mike
Was afraid you were going to say the fairing half had to come off. Think I knew that already but was in denial. Didn't have a clue how to get the switch out though. Thanks for the info and pictures.
Ohio Mike
Ohio Mike
Mike in Celina
