zg 1200 front brake switch
big0078
Current bike(s): 2003 1500 Vulcan Classic
1991 ZG1200 Voyager XII
1982 450 Honda Night Hawk
1993 ZG1200 Voyager XII
Post by big0078 »
Where in the world can a person get a 91 ZG 1200 front brake switch for the front master cylinder the tabs are loose inside for the brake light cruise part works fine. If you hold wires just right the front switch works low and behold brake lights. Next I have to chase down rear brake switch not working at all. The cruise cancel switch seams to be working.
Re: zg 1200 front brake switch
A kaw dealer or online About $36
http://www.partzilla.com/parts/search/K ... parts.html" onclick="window.open(this.href);return false;
Bill O
2003 1200 Voyager
Been liked: 6 times
Post by Bill O »
big0078 wrote:Where in the world can a person get a 91 ZG 1200 front brake switch for the front master cylinder the tabs are loose inside for the brake light cruise part works fine. If you hold wires just right the front switch works low and behold brake lights. Next I have to chase down rear brake switch not working at all. The cruise cancel switch seams to be working.
I have had great luck with an electric contact cleaner sprayed into the front break switch to resurrect faulty operations. If the spade connector are loose, just crimp then with a pair of pliers to make them tighter.
Bill O
P.S. The switch is the same for all 1200 Voyagers (at least from late 1987 on).
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
big0078
Post by big0078 »
Alas Bill it's the spade inside the switch not the slip on connector but thanks. The bike is new to me and I'm finding evidence it has been down just not too hard. :bat:
chevyman1
Been liked: 16 times
Post by chevyman1 »
The rear switch may just need adjusting or there is a relay for the brake lights that might be bad.
the relay will be one of them that is above the headlight.
:thmup:
