Starter Clutch replacememnt
shesseltine86
Current bike(s): 1986 Voyager 1200 XII
Post by shesseltine86 »
has anyone ever changed out the starter clutch? I downloaded the manual and it appears that i have to remove the engine?
Glad to be riding again!
Previous bikes: 01 Harley FXDX
98 Suzuki Bandit 1200
01 Suzuki Bandit 600
85 Suzuki 850
76 Yamaha 360
Lucasind
and a bunch of parts !
Has liked: 180 times
Been liked: 69 times
Re: Starter Clutch replacememnt
Post by Lucasind »
viewtopic.php?f=15&t=10025" onclick="window.open(this.href);return false;
shesseltine86
already started, downloaded the manual and printed off the needed pages! I appreciate having a forum like this to help with a 30 year old bike!!!
85 Suzuki 850
76 Yamaha 360
Lucasind
Post by Lucasind »
:thmup: it's a big job, good luck with your project . one thing is for sure.... you'll definitely know your new bike thoroughly by the time your done !
Gator Mike
2002 Honda 750 ACE
1969 Honda 90
Post by Gator Mike »
Mark all the plugs and take lots of pictures especially harness routing. Had mine out for transmission problems and really appreciated the pictures on reassembly. Good luck
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
scott, on an 86 i would be willing to bet a case of beer you will need a starter chain and tensioner, not a starter clutch....been there almost 100 times.....
shesseltine86
Thanks guys, I will have the engine out tomorrow, thanks for the advice on the chain!
85 Suzuki 850
76 Yamaha 360
shesseltine86
shesseltine86 wrote:Thanks guys, I will have the engine out tomorrow, thanks for the advice on the chain!
Here are the symptoms, most of the time you just hear the starter spin and it does not engage, if you put the bike in gear and rock it back and forth, you can get it to catch occasionally
85 Suzuki 850
76 Yamaha 360
shesseltine86
Got the clutch out and it's definitely bad! Anything else I should look for while I'm waiting for parts to come?
85 Suzuki 850
76 Yamaha 360
Lucasind
Post by Lucasind »
AWE....c'mon Scott ! ....your just saying the starter clutch is bad, to get a FREE case of beer from Carl ! :gig: :laughing:
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
he only needs to let me know what he prefers and where to send it......carl
shesseltine86
No beer required! Thanks for the input!
85 Suzuki 850
76 Yamaha 360
Tonyvdb
1981 GPZ 550 (Previous bike)
Post by Tonyvdb »
Have you looked to see what Igniter model your '86 has? if its part number 21119-1179 change it immediately before you do break the starter chain (over-advancing the ignition timing). You want part number 21119-1248
shesseltine86
Tonyvdb wrote:Have you looked to see what Igniter model your '86 has? if its part number 21119-1179 change it immediately before you do break the starter chain (over-advancing the ignition timing). You want part number 21119-1248
Thanks for the heads up!!
85 Suzuki 850
76 Yamaha 360
shesseltine86
I do have the good one, and a spare from the parts bike i picked up, thanks for the heads up!
85 Suzuki 850
76 Yamaha 360
shesseltine86
When I put this back together, any recommendations on what to use between the upper and lower cases of the transmission?
85 Suzuki 850
76 Yamaha 360
Lucasind
Post by Lucasind »
Kawasaki recommends the use of "Kawasaki Bond" here.
But I think at $50. a tube you could use another high temp silicone from your local auto parts store would do .
http://www.kawiforums.com/ninja-650r-er ... 004-a.html" onclick="window.open(this.href);return false;
http://www.mudinmyblood.net/forum/23-ka ... titue.html" onclick="window.open(this.href);return false;
I just checked, and here is the Kawasaki product on amazon for around 20 bucks, cheaper than at bike shops,but this is the small 2.5 oz. tube.
http://www.amazon.com/Kawasaki-Liquid-K ... B008744EPI" onclick="window.open(this.href);return false;
chevyman1
Been liked: 15 times
Post by chevyman1 »
I have used something called (3 bound 1184 liquid gasket) I got it at Off Road Motorsports, A dealer near me.
Any motorcycle shop should have it, I don't think I payed much for it less then $10 for a tube.
:thmup:
long or shout. (kew427@comcast.net)
ghostler
Has liked: 2 times
Been liked: 10 times
Post by ghostler »
I've been using Permatex Ultra Gray RTV, used for things like auto transmission cases. Still seals when spread very thin. Certainly is cheaper than Yamabond. Also works on forming gaskets for model airplane engines and joining lawnmower case halves. :hpdc:
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
shesseltine86
Thanks guys, I appreciate the help! I know how to spin wrenches, but I've never torn a motorcycle apart this far. I was surprised by how thin the spring was inside the starter clutch was.
85 Suzuki 850
76 Yamaha 360
