Peg and I tried out our new Sena units on our MAV trip and found they worked exactly as we wantedcushman eagle wrote:Well,based on what was written on this forum,and responses I saw on research I did on the Sena SMH 10,Peg and I went to our local Motorcycle Store,J&J Cycle in Massillion.We checked out and bought one for $309.It should come in the mail on Thursday,and if I am not in Kentucky harvesting corn,I will install it and hope it works better than the G9
cushman eagle wrote:Peg and I tried out our new Sena units on our MAV trip and found they worked exactly as we wantedcushman eagle wrote:Well,based on what was written on this forum,and responses I saw on research I did on the Sena SMH 10,Peg and I went to our local Motorcycle Store,J&J Cycle in Massillion.We checked out and bought one for $309.It should come in the mail on Thursday,and if I am not in Kentucky harvesting corn,I will install it and hope it works better than the G9
They are much easier and more consistant to pair up with each other, and once paired will stay connected until they are shut off.
Also, once they are paired, and the GPS is turned on,it will break into my headset to give directions,then allow us to talk until giving more directions.
These people who are giving the UClear a bad rep are either not computer knowledgeable or just don't like the fact that without using a boom microphone these units perform outstandingly at highway speeds and have a preference for another device. I can tell you without equivalence that there is no echo from other users in your group including your passenger providing you don't turn the volume to max expecting not to be able to hear at speed. If I believed just half of the posters on Amazon there isn't a single product I would buy.SgtSlag wrote:We use the Sena SMH10's as well. Work far better than our previous Scala Rider Q2 sets (Blech!). Looked at the UClear set on Amazon, but the questions, and some reviews, state that they pick up the other person's voice, creating an echo, which is intolerable, when using for rider/passenger (apparently, they use high-gain microphones). One person commented that after performing a firmware update on his units, this went away. Would be worth trying them, for the price, as Amazon has a good return policy, if not satisfied. Be sure to read the reviews, and questions, carefully, to make an educated guess before ordering. Cheers!
Get the little gizmo that plugs into your cigarette lighter that has a USB plug on it. Available at most auto supply stores, Sams, Walmart, everwhere! Use the Sena charge cable to plug in, and as long as you have a motorcycle battery, the Sena's will work. This is our last-ditch-emergency-when-all-else-fails solution that we use. This year, we also got one of those 28000 MA Hour bricks off of Ebay, wife uses that to keep her cell phone operating, it has a better GPS than our Garmans!cushman eagle wrote:I like them very muchThey do everything i ask of them,are easy to pair up,and stay paired until I shut them off.I have never exceeded battery life,so i do not know how long they will operate before needing charged.The longest ride since buying was 350 miles,but they still functioned the next day before we charged them.They are also easy to pair up with the GPS,Which only intrudes with my communictions with my wife when it is giving me directions
