I finally finished the 1200 and down off the lift. Now that it was off the lift the only items were the trunk and bags. So on a balmy morning with a light rain coming down I ventured out to the shop to wrap things up. Upon turning on the radio I was informed the date was 02\02\2020...... Well I just had to get out for a bit. Shut the heat off and opened up the garage door and the rain stopped and the sun was trying to make an appearance. Got the bike done and backed out into the drive. She started up the same as always and was ready to go.....So I went in the house changed into gear for a 41 deg day , and when I went back out, just 15min later , the sun was no where to be found and the clouds came rolling in. Just a light drizzle I said to myself
Well it was not a long run , 14 miles out and 14 miles back. Not bad for a road test after all the work that was done, and glad I had no issues because I never stopped to inspect anything. It was 14 miles to a coffee stop and I kept one glove on with the coffee in the other hand, Man I was chilled.....It was a 70 mile per hour run on that first 14 miles and when I pulled over for that break , I dared to let go as it went down to the dreaded 30 mph speed.... No wobble at all. I did allot to the front end, head set /torque, new wheel brg's, new AVON, A real good wheel balance, The ride home was an easy low speed cruise, trying to warm up a bit, hiding behind the wind shield . This old mans body just don't like the cold as much as I did when younger.
What I did notice , is that it was well worth replacing the wheel damper / and driven hub... What a smooth shifting trans. Like it was brand new. In 100k the spines had quite a bit of backlash . The 1200 however was a dirty mess from the wet roads , glad I did not give it a good cleaning yet...So just 28 miles for the new year is all I can claim. May try aging this weekend..
Gene Kap.
