I started by pulling the carbs and tank for cleaning, Drained the anti-freeze, repaired the metal radiator hoses which attach to the heads between cyl 1&2, 3&4(lots of corrosion there including a pin hole which I've welded), changed the rest of the fluids etc... and I'm pretty close to putting it all back together.
Have to say I found a GOLD MINE of information HERE in this forum THANK YOU everybody!
My question is with the carbs... The Pilot screws seem a bit NUTZ.... Still had the ?original? (maybe not) CAPS - however they were set as follows:
#1 - *maybe* 1/8 turn out (practically closed)
#2 - just over 2 turns out
#3 - just over 1 1/2 turns out
#4 - just over 1 1/2 turns out
Most instructions seem to say put 'em back to original - but these settings seem pretty crazy to me..-- am I off base? Should I really put them back that way? or can I assume they were set badly last time? --- I kinda feel like trying them all at 1 1/2 or something like that - don't know... I'm pretty sure the carbs have been out before because one of the rubber boots had a lip folded over and wasn't sealing .
I'm looking for SAGE advice here first, before I just dork with it ha!
