94 voyager 1200 no headlight or dash lights
mrutah12
4
Has liked: 3 times
Post by mrutah12 »
I have a problem my headlight and dashlights dont work everything else works fuses are good headlight bulb is good I have no power to them no power at dimmer switch either please help point me to things to look at
Has liked: 893 times
Been liked: 315 times
Re: 94 voyager 1200 no headlight or dash lights
Welcome, mrutah12,to the AVA forum :thmup:
The 1st thing I would check out is the ignition switch harness that wraps around the steering head.That harness is often tied too tight to the steering head, that it bends with every move of the handle bars,and breaks the wires.
Mine had failed at 22,000 miles,12 years ago when I bought the bike,and had been patched in 2 places.I had the harness rewired and reinstalled it loose,and 75,000 later,have had no problems with it :woohoo:
You can research the harness on the forum to show how to access it. :hmm:
Been liked: 106 times
Also check 10 pin connector that goes to the fuse box underneath left upper fairing and faux tank. Known to corrode and cause these kinds of problems. I cut mine out and hard wired it.
cushman eagle (Sun Jul 25, 2021 12:46 am)
mrutah12
4
Has liked: 3 times
Post by mrutah12 »
:thanks: I got it fixed it was the wires coming out of the fuse box so I cut the plug out and hard wired it now everything works even found the wire to oil sensor was loose tighted that up now the oil light battdry light and low fuel light come on :thanks:
These users liked mrutah12's post:
GrandpaDenny (Sun Jul 25, 2021 12:47 pm)
Glad you got her fixed so easily :woohoo:
