Any quick tips on intake duct spring?
- Heavy Armor
- Has liked: 10 times
- Been liked: 26 times
I'm >this< close to having my carbs back on and sunnuva%^$&!, one of those stinkin' duct springs, the ones that are a PITA to roll back on, popped apart. And of course it's on cylinder 3, so it's impossible to reach down in there. Any tips on just how the heck I can get this thing wrapped back around and hooked without pulling the whole system apart???
- Been liked: 39 times
Re: Any quick tips on intake duct spring?
I have used thin red xmas ribbon looped around the springs in the past ...long enough to grab and pull then it slides out nicely. still awkward.....
- These users liked buzzcut's post:
- cushman eagle (Mon Jul 11, 2022 7:57 pm) • ekap1200 (Wed Jul 13, 2022 6:57 pm)
- Has liked: 245 times
- Been liked: 634 times
I think it's best to be careful about setting things up right to carefully roll the spring into position from further on the boot. But when I can't do that, I've saved the install by using a piece of stiff wire bent into a hook. At least do your best to get the spring on right where you can't reach it.
And once you got it on, take some Valium. You earned it.
- Heavy Armor
I managed it in about 20 minutes during lunch today, just some dumb luck.
I used the wire trick... I have some really stiff stuff that I cut an 8 or 9" piece of and hooked the end, and threaded it like a sewing needle around the #3 duct, leaving both ends of the spring exposed below the carbs on the right side of the bike. I slipped the loose end of the spring through the wire also, like I was tying a knot, so that both ends of the spring pulled together and touched while wrapped around the duct. I did this two different times, experimenting with how to pull one spring end loose and hook it, and always losing my grip before I figured it out. The 3rd time however, the ends actually got tangled WHILE they were on the wire, and they hooked all by themselves!
I very carefully slid my wire out of both ends and then gently rolled the spring into position. Good to go!
And I never, EVER wanna do it again.
- These users liked Heavy Armor's post:
- cushman eagle (Mon Jul 11, 2022 7:58 pm)
To clarify, I install the springs already connected. Put them around the boots before reinstalling the carbs, and then roll them into position once the carbs are installed. I also put a little vaseline on the carbs or boots because they can be ornery about slipping on. Like bacon, everything's a little better with vaseline.
- Heavy Armor
Right, right. Definitely the preferred method. Mine just popped loose when I had everything about 80% aligned, and I was afraid to pull it all back out to put the spring back on. I thought "Eh, I'll deal with it last", and that was a real PITA!Nails wrote: ↑Tue Jul 12, 2022 7:49 am To clarify, I install the springs already connected. Put them around the boots before reinstalling the carbs, and then roll them into position once the carbs are installed. I also put a little vaseline on the carbs or boots because they can be ornery about slipping on. Like bacon, everything's a little better with vaseline.
- Has liked: 512 times
- Been liked: 455 times
You put Vaseline on your bacon? That explains a lot.
- Nails (Tue Jul 12, 2022 7:20 pm) • Sidehopper (Sun Jul 17, 2022 4:56 pm)
