Need some clutch help!
- woodsm84
- Current bike(s): Dr650
VRSCA 2003
Voyager XII - Has liked: 22 times
I replaced my clutch plates and springs. First time ever with the help of some service diagrams. Now I barely have any throw on my clutch lever. Feels locked up. I’m assuming I have to remove the case to readjust, but I’m not sure where to do the adjustment. Any advice is greatly appreciated.
- Has liked: 906 times
- Been liked: 316 times
Re: Need some clutch help!
Hello, woodsm84.
Did you replace, flush,and bleed your clutch fluid.
If you did and the fluid went through the master cylinder,line, and the bleeder ok,I am going to guess that one of the discs got indexed wrong and you cannot compress the pack properly.
There is no adjustment on the clutch as it adjusts hydraulically as you use it.
Please let us know what you find out
- woodsm84 (Fri Jan 20, 2023 12:04 am)
- woodsm84
VRSCA 2003
I’m thinking it has to be the indexing like you said. I did a full bleed/flush. Looks like I’ll be redoing this one
- woodsm84
VRSCA 2003
Definitely will. I’m going to reorder plates and springs. I’m not sure if I need to adjust anything at the basket. Basically, last time, I drained the motor, pulled the basket cover, replaced and oiled new disks and springs, then put it all together. Then nothing on the lever throw. Not sure which rookie mistake, but I’m sure it’s there.
- Has liked: 512 times
Sounds like you didn't index the first plate (last one you put in) - it doesn't go in the same slots as the rest. There is nothing to adjust.
- Bonnie and Clyde (Sat Jan 14, 2023 11:44 am) • cushman eagle (Sat Jan 14, 2023 2:40 pm) • woodsm84 (Fri Jan 20, 2023 12:04 am)
- Rating: 33.33%
GrandpaDenny,I would agree with you
- woodsm84
VRSCA 2003
Here’s a photo of it as I was putting it back together. Not sure if you can identify anything?GrandpaDenny wrote: ↑Sat Jan 14, 2023 6:04 am Sounds like you didn't index the first plate (last one you put in) - it doesn't go in the same slots as the rest. There is nothing to adjust.
ok the indexing looks good near as I can tell. It all looks good. When you say "hardly any throw", what exactly do you mean? Does the clutch disengage almost immediately when pulling the lever, or does it engage almost immediately when releasing, or does the friction zone seem tighter than before?
- woodsm84
VRSCA 2003
It moves about 1/4 inch and stops dead at that point. When I was bleeding the clutch afterwards, my master cylinder was shooting brake fluid in the air if I squeezed too quickly. As soon as I close the bleeder line at the slave cylinder, I have no throw. Have I over torqued the pressure plate springs maybe?GrandpaDenny wrote: ↑Wed Jan 18, 2023 9:49 am ok the indexing looks good near as I can tell. It all looks good. When you say "hardly any throw", what exactly do you mean? Does the clutch disengage almost immediately when pulling the lever, or does it engage almost immediately when releasing, or does the friction zone seem tighter than before?
- Van Voyager
- Has liked: 52 times
- Been liked: 44 times
That's normal, and a good sign - it means the master cylinder equalizing port is not plugged.
woodsm84,I was wondering what you have accomplished on your clutch?
We have not heard from you for a couple days.
- woodsm84 (Thu Jan 26, 2023 8:21 am)
- woodsm84
VRSCA 2003
Fixed!!!!!!! One disc, one plate too many. Never trust parts from eBay. I did everything correctly, unfortunately the parts vendor did not. Thanks so much for everyone’s helpcushman eagle wrote: ↑Tue Jan 24, 2023 5:16 pm woodsm84,I was wondering what you have accomplished on your clutch?![]()
We have not heard from you for a couple days.![]()
- These users liked woodsm84's post:
- GrandpaDenny (Wed Jan 25, 2023 6:40 pm) • cushman eagle (Wed Jan 25, 2023 7:13 pm)
Thank you for the good news,woodsm84
It is always good to hear of a successful,easy fix
- woodsm84 (Thu Jan 26, 2023 8:20 am)
- Been liked: 83 times
I think you have some clutch plates that are wrong. Measure the thickness of your old plates, then Measure your new plates. Now you'll find that the old metal plates might be thinner. Now Measure the old clutch pack vs the new clutch pack. You want the new clutch pack to be just a little thicker then the old.
Why are you changing your clutch. Is the clutch slipping when you try to accelerate in the higher gears? If so you might have broken spyder springs, which are at the back of the clutch basket.
- woodsm84
VRSCA 2003
It turned out to be exactly what you said about the plates! Thanks!HMB Don wrote: ↑Sat Jan 28, 2023 10:50 am I think you have some clutch plates that are wrong. Measure the thickness of your old plates, then Measure your new plates. Now you'll find that the old metal plates might be thinner. Now Measure the old clutch pack vs the new clutch pack. You want the new clutch pack to be just a little thicker then the old.
