Water pump
- Lance McCaw
Water pump
Well I replaced my water pump seal and all the o-rings. I still have a slight leak. May order another seal and try that. No oil is dripinv on the floor cause it hits exhaust and burns. Should I even mess with it again. I thought about double sealing it. There is plenty of room for two seals. Opinions, thoughts ?
- bikerking.biz
Re: Water pump
Are you absolutely sure it is the water pump leaking? Thought mine might have been, but it wasn't, still have an oil leak and so far unable to find where.
Biker King
http://www.bikerking.biz
Re: Water pump
Gear oil leaking from the final drive will work its way forward on the drive shaft and leak out the boot onto the pipes. Just smell the oil you see, gear oil has a smell of its own.bikerking.biz wrote:Are you absolutely sure it is the water pump leaking? Thought mine might have been, but it wasn't, still have an oil leak and so far unable to find where.
- Lance McCaw
Re: Water pump
After looking at my pictures during disassembling it could be the front bevel gear cover. which is the front end of the drive shaft.
