slipping clutch
- Gator Mike
2002 Honda 750 ACE
slipping clutch
Does anyone know if the 2007 Kawasaki Nomad 1600 has the same slipper Springs in the clutch assembly that breaks on our voyagers. I have a nephew with a nomad that has a slipping clutch when he really gets on it.
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
- Van Voyager
- Has liked: 51 times
- Been liked: 44 times
Re: slipping clutch
The 1600 motor has a true slipper clutch (sorry, I don't know if it's the same design as the Voyagers). Not unusual for the 1500/1600 motor to exhibit clutch slippage. The Meanstreak (1500 originally) upgraded some clutch spring and related parts to combat premature clutch slippage and those parts were later 'retro-recomended' for all 1500/1600 models. I suspect your Nomad does not have the upgraded parts. Changing to the new parts will probably solve your problem (and I'd change out the fiber plates while I was in there unless they've been changed recently already).
Re: slipping clutch
... new clutch hardware was implemented in the 1600s... he has the better washer and
added spacer. I put those pieces in my 1500 rebuild. FWIW
