throttle ??
jake100
Current bike(s): 92 voyager
throttle ??
Post by jake100 »
I have a 92 model and let me start by saying I am a pretty conservative rider I normally shift at 3k rpm and rareley go over 65 mph so the other day I decided to crank her tail a bit but it would not go over 4k and if I give it full throttle it dies put in a new fuel filter same thing seems to pull smoothly up 3500 rpm and run steadily at speed ??????
Re: throttle ??
More than likely your high speed jets are clogged. It may require a carb cleaning.
Re: throttle ??
.... run a few strong tanks of Seafom thru’er....JM2C
jake100
Re: throttle ??
Post by jake100 »
yup seafoam is the magic stuff :-D :-D
Has liked: 100 times
Been liked: 69 times
Re: throttle ??
Post by Barry »
Have you opened the drain screws on the bottoms of the float bowls to see if you get clean or dirty fuel?
