Handlebar Weight Screws - Thread-locker
Van Voyager
Has liked: 52 times
Been liked: 44 times
Post by Van Voyager »
Decided to put the original handlebar weights back on my 86 ZN1300. The OEM screws appear to have Red Loctite (or some kind of thread-locker) on them and I've read some horror stories about removing those screws once they're installed. I'm considering 'wheeling' the thread-locker off the screws - maybe use some purple thread-locker - just wondering what other folks have done.
Me Again
Been liked: 286 times
Re: Handlebar Weight Screws - Thread-locker
Post by Me Again »
I would be more inclined to use anti seize than thread lock.
You will probably never take them off again though
Van Voyager
Has liked: 52 times
Me Again wrote: Sat Jun 22, 2019 8:39 am I would be more inclined to use anti seize than thread lock.
Thanks ME.
The weights will stay on but they'd have to come off if I swap grips (if I were to ever find a set that fits) or need to take other bits off the bars.
I'm also inclined to use anti-seize. Having said that, I had the weights fastened on with some bolts while waiting for the OEM screws to come in and the throttle size kept coming loose. :shock: . I'm going to take the thread locker off for now and if things loosen up, I can always put a little dab back on.
I broke off the allen bolts on the bar weights on my 1200. Replaced them with industrial allen screws in Black Steel. I did not use any thread locker or anti seize and they work just fine. The Throttle side I let the bar end spin. The left side is tight up against the grips so it wont.
